EtherChannel with Packet Tracer
mostafasawy86
I tried in Packet Tracer to bundle 4 links between 2 switches, each switch is connected to a host.
when I try to ping from host to other, it pings and successful, but when I try to disconnect a cable, which the selected link by the PAgP, it says Request timed out.
and it can't ping till I return that cable back again, what is the problem?
6 Replies 6
Reza Sharifi
Can you provide the configs from both switches?
on first switch:
Switch1>enable
Switch1#configure terminal
Switch1(config)#interface range f0/1-4
Switch1(config-if-range)#channel-protocol pagp
Switch1(config-if-range)#channel-group 1 mode auto
on second switch:
Switch2>enable
Switch2#configure terminal
Switch2(config)#interface range f0/1-4
Switch2(config-if-range)#channel-protocol pagp
Switch2(config-if-range)#channel-group 1 mode desirable
What type of switches are these?
2950, I use packet tracer.
Hello, i have packet tracer 6.2, and i use Switches 3560(L3), my portchannel have two ports, when i reload de Switch1, after to startup the Switch appear this message
%EC-5-CANNOT_BUNDLE2: Fa0/1 is not compatible with Po1 and will be suspended (trunk encap of Fa0/1 is auto Po1 is dot1q)
%EC-5-CANNOT_BUNDLE2: Fa0/2 is not compatible with Po1 and will be suspended (trunk encap of Fa0/2 is auto Po1 is dot1q)
Do you Know what is the problem
CONFIG S1
interface Port-channel 1
switchport trunk allowed vlan 10,20
switchport mode trunk
interface FastEthernet0/1
interface FastEthernet0/2
CONFIG S2
  On S2 define the trunk encapsulation on the interfaces themselves and then bounce the port-channel  .
