Etherchannel
rajsingh68
Frequent Visitor
Frequent Visitor
I have 4506 standard sup V.  Protocol is used HSRP . We are facing the issue to outdrop is increase at couple of port (2/5) out of 5. But there is no service impact.
There is 5 ports in etherchannel.
Please suggest
thanks
2 Accepted Solutions
Pawan Raut
Level 10
Level 10
You mean output drop? Can you share sh int output o those interafce
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Etherchannel port loading is impacted by the "nature" of your traffic and the load balancing algorithm being used.  Sometimes a different load balancing algorithm will better distribute your traffic.  However, even the most optimal choice doesn't avoid the situation that individual flows are going to be directed to particular ports w/o regard to actual load on those ports.  I.e. a very active/busy flow, or flows, might congest a port no matter what you do.
Also BTW, on a Sup V, I recall best load distribution might be achieved by using a power of 2 for your number of ports within an Etherchannel, i.e. your choice/usage of 5 ports will generally also contribute to unequal load distribution.
8 Replies 8
Pawan Raut
Level 10
Level 10
we have two core switches, CS01 is connected with CS02. Protocol running is HSRP / PVST. switch details given below CS-1:- cisco WS-C4506 (MPC8245) processor (revision 4) with 524288K bytes of memory.  Processor board ID FOX1120147U  MPC8245 CPU at 400Mhz, Supervisor V  Last reset from PowerUp  32 Virtual Ethernet interfaces  146 Gigabit Ethernet interfaces  511K bytes of non-volatile configuration memory  IOS :- :cat4500-entservicesk9-mz.150-2.SG8.bin  CS-2 cisco WS-C4506 (MPC8245) processor (revision 4) with 524288K bytes of memory.  Processor board ID FOX1120148L  MPC8245 CPU at 400Mhz, Supervisor V  Last reset from PowerUp  32 Virtual Ethernet interfaces  146 Gigabit Ethernet interfaces  511K bytes of non-volatile configuration memory.  IOS : cat4500-entservicesk9-mz.150-2.SG8.bin
can you post the interface from each member of the port-channel and the port-channel interfaces as well so we can see the problem
Also post the the sh run interface of each port-channel
and --sh run | i load
Dear Sir
Please find the output
EtherChannel Load-Balancing Configuration:
        src-dst-mac
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
  IPv4: Source XOR Destination MAC address
  IPv6: Source XOR Destination MAC address
Age of the Port-channel   = 31d:16h:03m:12s
Logical slot/port   = 11/10          Number of ports = 5
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  1     00     Gi3/20   Active             0
  0     00     Gi3/47   Active             0
  4     00     Gi4/3    Active             0
  3     00     Gi4/20   Active             0
  2     00     Gi4/48   Active             0
Time since last port bundled:    14d:22h:09m:36s    Gi4/3
Mark Malone
make sure your load balancing correctly with the etherchannel and not all traffic is going down one link only causing it to drop
alter it if you need to
(config)#port-channel load-balance ?
  dst-ip                      Dst IP Addr
  dst-mac                     Dst Mac Addr
  dst-mixed-ip-port           Dst IP Addr and TCP/UDP Port
  dst-port                    Dst TCP/UDP Port
  mpls                        Load Balancing for MPLS packets
  src-dst-ip                  Src XOR Dst IP Addr
  src-dst-mac                 Src XOR Dst Mac Addr
  src-dst-mixed-ip-port       Src XOR Dst IP Addr and TCP/UDP Port
  src-dst-port                Src XOR Dst TCP/UDP Port
  src-ip                      Src IP Addr
  src-mac                     Src Mac Addr
  src-mixed-ip-port           Src IP Addr and TCP/UDP Port
  src-port                    Src TCP/UDP Port
  vlan-dst-ip                 Vlan, Dst IP Addr
  vlan-dst-mixed-ip-port      Vlan, Dst IP Addr and TCP/UDP Port
  vlan-src-dst-ip             Vlan, Src XOR Dst IP Addr
  vlan-src-dst-mixed-ip-port  Vlan, Src XOR Dst IP Addr and TCP/UDP Port
  vlan-src-ip                 Vlan, Src IP Addr
  vlan-src-mixed-ip-port      Vlan, Src IP Addr and TCP/UDP Port
Aswell is there qos running on the link ?
you may be spiking queues if the buffer is filling
If you provide more information what your seeing exactly and some config in place we can help further , there is not enough information yet to suggest what the issue is
Dear sir
thanks a a lot
regqards
raj singH
09871285855
Dear sir
Please find the details
 show config  | i load
port-channel load-balance src-dst-mac
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
 load-interval 30
regards
raj singh
Joseph W. Doherty
Disclaimer
Posting
