09-05-2016 01:03 AM - edited 03-08-2019 07:17 AM
Have a good time.
09-05-2016 01:30 AM
how did you configured the Port-channel? Can you provide the output of the commands from each 3560... "show run int Po1", "show run int Fa0/23", "show run int Fa0/24"... thanks!
09-05-2016 02:38 AM
Thanks for asking before i just found mismatch in my configuration.I have found that this error displayed, when the vlans assigned to port-channel and interfaces were not same, it did not retrieve correctly, appling this change I got my interfaces in a group, as it is better to know that etherchannel required same configuration on all interfaces..
Have a good time.
09-05-2016 02:48 AM
Obviously this is true. Good job!
