ethernet OAM not detecting the UDLD
jigojar
 i have tried to configure the Ethernet OAM between Cisco switch and Huawei Switch, Pls find the below topology
Topology:
Problem Observed
  1. When we tried to remove the single core from the Huawei switch then both the switch interface down
  2. We have enabled the error recovery on both the switches
  3. After the recovery interval cisco switch connected interface is came up(Te1/16) due to this we are facing the unidirectional issue
Configurations:-
Cisco 4500:-
interface TenGigabitEthernet1/16
 description XCNT-HUAWEI-124.7.227.57-Gi0/0/26
 switchport trunk allowed vlan 400
 switchport mode trunk
 mtu 9198
 speed nonegotiate
 ethernet oam remote-loopback supported
 ethernet oam remote-loopback timeout 10
 ethernet oam timeout 10
 ethernet oam link-monitor frame threshold high 10
 ethernet oam link-monitor receive-crc threshold high 10
 ethernet oam link-monitor high-threshold action error-disable-interface
 ethernet oam remote-failure link-fault action error-disable-interface
 ethernet oam remote-failure critical-event action error-disable-interface
 ethernet oam
end
Huawei S5700:-
interface GigabitEthernet0/0/26
 undo negotiation auto
 description XCNT-4500X-SW-100.65.181.71-Te1/16
 port link-type trunk
 undo port trunk allow-pass vlan 1
 port trunk allow-pass vlan 102 400
 stp bpdu-filter enable
 stp edged-port enable
 efm enable
 efm error-frame notification enable
 efm error-frame-second notification enable
 efm error-code notification enable
 efm threshold-event trigger error-down
 efm link-fault trigger error-down
 efm timeout trigger error-down
jigojar
 Pls find the attached logs.
HI anyone can help thi subject issue?
