Ethernet
nabhishek
Community Member
I came across a formula.
Time to detect a collision = 2 x Signal Propagation time
This means that a longer network diameter will have a smaller data rate.
10 Mbps = 2500m
100 Mbps= 250m
1000Mbps= 20m
Does this mean that this is the only factor that affects speed of transmission?
what would be the others factors that need to be considered?
dsweeny
Level 6
Level 6
As you know that time is inversely proportional to frequency (in HZ). Low band width and Jitter are another factor that affects delay.
