ethetnet with snap header
sarahr202
Level 5
Level 5
Hi every body.
I have few questions about Snap header in the 802.3 ethernet.
My book says"  another popular option exits for the protocol type field,particularly when sending ip packets. If the 802.3 type/length has a value less than 1536,the type/length field is used as length field for tthat frame,identifying the length of entire frame. In that case another field is needed to identify the type L3pdu inside the frame. "    Snap header is inserted the frame to identify the L3pdu.
My question is how common is it to find ethernet  with snap header carrying ip packets?  Most of the  ip packet i captured using wire shark,  use the  802.3  ethernet where type field is used to indicate the encapsulated ip packet.     Is it common for ip packets to use ethernet framing weith simply" type" field?
thanks  and have a nice weekend.
Giuseppe Larosa
Hello Sarah,
we probably had discussed this in some older thread
It is really difficult nowdays to find an IP packet encapsulated in an ethernet frame without using Eth II
The reason is that it is not efficient to use SNAP it adds a bigger overhead (up to 8 bytes overhead 3 bytes LLC 5 bytes SNAP 3 bytes oui + 2 bytes protocol type )
There are however some protocol messages that use this kind of encapsulation or similar
(these use only LLC header to be correct)
ISIS frames
ISO CLNP
STP IEEE standard BPDUs
Also SNA traffic use this kind of encapsulation (LLC encapsulation I mean, again to be correct)
so with some patience connecting to a LAN switch you could capture an STP frame and you could see the DSAP SSAP and other fields
So  your book may have reported a sentence from an older book or it is old itself
Edit:
in the following link you can see a list  of L2 signalling  protocols like CDP, VTP, DTP and they use SNAP
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml
Have a nice weekend
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
ISIS frames
ISO CLNP
Edit:
Have a nice weekend
Hope to help
Giuseppe
Thanks Giusepppe. you too have a nice weekend.
