Excessive Total output drops
justfish
                   I have a VOIP system and have been fighting a couple phones dropping mid call.  I recently added ' auto qos voip trust' and increased the In/Out buffer to help with this issue.  I'm not certain if that will resolve the issue but I'm having difficulty resetting the Total Output Drops counter so I can see if I'm still getting the same frequency with the new commands in place.  Anyone know if that counter is able to be reset w/o a reboot?
Fred
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If clearing interface counters doesn't clear the counter of interest, then a reload would usually be needed to clear it.
Thank you Joseph, I will try that after hours.  And not worries about holding you responsible for my issues due to your suggestion!
