Exit Interface Found: None
peter_huber
I am trying to configure my Cisco Router 1921 for home networking. When testing the outside connection, I get the error message
I am using a cable modem to access the internet.
Thanks a lot!
Current configuration : 6842 bytes
version 15.1
hostname habsburg
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$MoY/$8a0962QftXIOGcDALI39X/
enable password XXXXXX
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool1
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
crypto pki trustpoint TP-self-signed-1139877488
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1139877488
revocation-check none
rsakeypair TP-self-signed-1139877488
crypto pki certificate chain TP-self-signed-1139877488
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313339 38373734 3838301E 170D3131 30393232 32303039
  33305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31333938
  37373438 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009781 CB60A527 8B809C47 DC331EC5 2D7271E3 34FF9D89 167928BD 4E810C16
  F0A4BAB0 10954AFF 88F8C409 9C3E0BF9 91E4A24A B2E1149D 2DEA157E 3D8118B0
  7A33B1C2 A678E459 DFBDB3E6 6D24044F BE469FC1 522B28C8 F2B8D81E 6195A59B
  607540AD 3A9F7010 DF6E95C9 4CDC3CBD E1FFA7CB E7B14657 94155B32 FA2DCFBE
  BD2F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14538718 6BA50169 1FD5A5A5 BF0A3B65 8A577033 80301D06
  03551D0E 04160414 5387186B A501691F D5A5A5BF 0A3B658A 57703380 300D0609
  2A864886 F70D0101 05050003 8181000E 5BB064C1 9738637F 70074CA6 F140CC2D
  B61A79AB 8C0DED4D F79854E1 BE61B5C0 CBD10F4F E48305E9 272122E6 09C51198
  735A743F 3935DB44 C4DC5575 AD8F7006 232971C3 C7709BF9 359FB0BC 2C0822BB
  F544A8B9 E79F72A8 CDA7862F E7F265DC 4F61AE8F 375575CC 1E9E3B48 8899CF8D
  5CCAFE83 839E2A46 30F137E6 21ED9C
            quit
license udi pid CISCO1921/K9 sn FCZ1535C0XL
license boot module c1900 technology-package securityk9
username phuber privilege 15 secret 5 $1$1S2h$E9snHLA6FIjmj9lQnrd0I.
redundancy
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface GigabitEthernet0/1
description $ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
zone-member security in-zone
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password XXXXX
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
3 Accepted Solutions
Richard Burts
Peter
I observe that your configuration does not have a default route configured. Therefore it does not know which interface to use because it does not know how to get to any address that is not locally configured.
I suggest that you configure a static default route to use the route provided by the DHCP server which might look something like this:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
You can use this link to find more information about using routes from the DHCP server:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/gtddgtwy.html
Rick
Rick
Peter
I suggest that you try this:
dns-server 62.2.17.60 62.2.24.158
Give this a try and let us know if it helps.
Rick
Rick
hi peter,
can try the below and test again. also try to disable PC FW/AV or perhaps use another PC for testing.
import all
ip route 0.0.0.0 0.0.0.0 dhcp
Router#renew dhcp gigabit0/0
28 Replies 28
Richard Burts
Peter
Rick
Rick
Rick
Thanks for this. I have added the ip route but still the same error message.
Show ip route looks as follows:
habsburg#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 80.219.128.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 80.219.128.1, GigabitEthernet0/0
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.10.10.0/24 is directly connected, GigabitEthernet0/1
L        10.10.10.1/32 is directly connected, GigabitEthernet0/1
S        10.145.128.1/32 [254/0] via 80.219.128.1, GigabitEthernet0/0
      80.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        80.219.128.0/22 is directly connected, GigabitEthernet0/0
L        80.219.128.170/32 is directly connected, GigabitEthernet0/0
Thanks for your help!
Peter
what test are you doing?
add this command: ip inspect log drop-pkt  and tell us what you're doing and if you get a log message.
Regards.
Alain.
I am testing the interface status via CPP . Ping outside addresses seems to work fine but I cannot access them via http.
Peter
Peter
I thought that clearly the lack of a default route was a problem and could logically lead to the error of Exit Interface Found: None. But now the router does have what appears to be a valid default route. If the same error is occurring then we need to look for something else.
When this error happens are you generating traffic from a PC connected to the router or are you on the router and generating the traffic from the router? And what kind of traffic are you generating?
I suggest that we start with something very simple and see how it works. Can you access the router (either through the console connection or through telnet or SSH) and from the router ping the gateway address of
80.219.128.1? Lets try that and see what happens.
Rick
Rick
Rick
I am using console connection. Pinging the gateway works fine from the terminal but also from a PC connected to the router:
habsburg#ping 80.219.128.1
Sending 5, 100-byte ICMP Echos to 80.219.128.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
Peter
Peter
Thanks. It is helpful to know that ping to the gateway works from the router and even better that it also works from a PC connected to the router.
I am wondering if it may be an issue with DNS and name resolution. Can you try a test where you attempt to access something in the Internet by name and then by IP address?
Rick
Rick
Rick
Thanks. We seem to get closer... I tried to access yahoo.com which did not work, 98.137.149.56/ on the other side works fine.
Peter
Peter
Yes I believe that we are getting closer.
Perhaps the next step is to verify whether the PC is learning any DNS server. Could you post the output of ipconfig /all from a PC that is connected to the router?
It might also be helpful to know whether the router has learned a DNS server via DHCP from the ISP. Probably the easy way to check that is to try to ping something in the Internet by name. If the router can ping by name then it has learned a name server.
Rick
Rick
Rick
I pinged yahoo.com. Message: unknown host.
As I am using a Mac, I cannot provide an ipconfig but I think ifconfig -a comes closest to it.
Peter-Hubers-MacBook-Pro:~ phuber$ ifconfig -a
lo0: flags=8049 mtu 16384
options=3
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
gif0: flags=8010 mtu 1280
stf0: flags=0<> mtu 1280
en1: flags=8823 mtu 1500
ether e0:f8:47:2b:63:ec
media: autoselect ()
status: inactive
p2p0: flags=8802 mtu 2304
ether 02:f8:47:2b:63:ec
media: autoselect
status: inactive
fw0: flags=8863 mtu 4078
lladdr 70:cd:60:ff:fe:d1:f8:8c
media: autoselect
status: inactive
en0: flags=8863 mtu 1500
options=2b
ether c8:2a:14:13:37:0f
inet6 fe80::ca2a:14ff:fe13:370f%en0 prefixlen 64 scopeid 0x7
inet 10.10.10.3 netmask 0xffffff00 broadcast 10.10.10.255
media: autoselect (1000baseT )
status: active
Looking at the CCP Test Connection, there seems to be a DNS server to be imported:
ActivityStatus
Checking interface status...Up
    Interface physical status :Up
    Line protocol status :Up
Checking for DNS settings...Successful
    DNS lookup set :Yes
    Statically configured DNS servers :None
    Dynamically imported DNS servers : 62.2.17.60 62.2.24.158
Checking interface IP address..Successful
    Interface IP address :10.10.10.1
    Interface IP address Type :Static
Checking exit interface...Failed
    Exit interface found :None
Hope this helps.
Thanks!
Peter
Peter
I think that this is a step forward. I am not a MAC expert and am not sure of a way to know whether it has learned any DNS server. But I am assuming that it has not and that this is the main problem. And I believe that the error message from the MAC about unknown host is confirmation of this.
I am not familiar with CCP and do not know how to tell it to import DNS information. But if you can tell it to do that then I believe that the problem will be solved. If you have trouble getting this done in CCP then there are ways to configure in the DHCP pool to include the DNS server information.
Also I realized (for the first time) that the exit interface found: None was actually a CCP message. I had assumed that it was some more general error message.
So give a try for importing the DNS and lets see what happens.
Rick
Rick
Still no luck despite the two DNS I added. I really have no clue, what could be wrong.
My config looks as follows.
Peter
Current configuration : 7204 bytes
! Last configuration change at 22:47:41 Berlin Sat Sep 24 2011 by phuber
! NVRAM config last updated at 22:47:30 Berlin Sat Sep 24 2011 by phuber
version 15.1
hostname habsburg
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone Berlin 1 0
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
no ipv6 cef
ip source-route
ip cef
ip name-server 62.2.17.60
ip name-server 62.2.24.158
parameter-map type inspect global
log dropped-packets enable
            quit
redundancy
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
  pass
  inspect
class class-default
  pass
  drop log
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
class class-default
  drop
  pass
class class-default
  drop
no ip address
shutdown
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no mop enabled
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 80.219.128.1
ip route 0.0.0.0 0.0.0.0 80.219.128.1 254
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
password XXXXXX
login local
line vty 5 15
privilege level 15
login local
end
Peter
Rick
Rick
Rick
Unfortunately it did not help.
br
Peter
