expansion of subnet created network problems
We have been  expended our subnet from 192.168.0.0/24 to 192.168.0.0/21.
We can ping some  stations others do not respond to ping.
Ip configuration is  the same on all printers we have been testing.
Z:\>ping  192.168.1.100
Pinging  192.168.1.100 with 32 bytes of data:
Reply from  192.168.1.100: bytes=32 time=1ms TTL=255
Z:\>ping  192.168.1.102
Pinging  192.168.1.102 with 32 bytes of data:
Reply from  192.168.1.102: bytes=32 time=3ms TTL=64
Reply from 192.168.1.102: bytes=32  time=4ms TTL=64
Z:\>ping  192.168.1.104
Pinging  192.168.1.104 with 32 bytes of data:
Reply from  172.20.1.226: TTL expired in transit.
I am really lost on  this. Please let me know what kind of info you want me to post I can make it  happen. If you dealt with same situation please help me out
I know that some say  that has to be some"user error" but all these three printers have same subnet and  default gateway
Thanks in  advanced
6 Replies 6
Jon Marshall
Can you post -
Host Z - IP address/subnet mask
all 3 printers - IP address/subnet mask
Jon
Giuseppe Larosa
first of all: are you using DHCP or each end user device is manually configured?
in second case all end user devices have to be tuned to update the new subnet mask.
this is because all devices have to agree on the directed broadcast that depends from subnets mask ( it is defined as all 1s in the host portion)
you should have added some new vlans with other /24 IP subnets associated to each of them. In this way you would have left untouched existing device
a /21 subnet is near to be too big (too many broadcasts)
if your environment has managed switches consider the use of multiple vlans
we see that first device answers with TTL=255 meaning it is on wire, second device uses 64 and should be a different settings, the answer for third ip address comes from another subnet.
this may mean that there is a routing loop somewhere in the network.
Hope to help
Giuseppe
HI Giuslar,
thank you very much for your detailed reply.
Can you please give me some more details about this line
i have about 5 cisco switches all ports are being used.
All servers have static ip's with /21 bit subnet , clients with dhcp for the meant time/24 bit subnet because we started to have all these network issues.
What is the best course of action would be for me at this point of time.
the network setup is flat , i.e we don't use vlans right now
Thanks again
Hello Vistek,
what type of switches have you got? if any is a  multilayer capable moving to multiple vlans would be easy
using 8 /24 IP subnets mapped to 8 different vlans should provide you a better network
Hope to help
Giuseppe
so in this case the best way is to split network into 8 subne
ts each with 24 bit, correct?
the way how our switches setup is a start so one main switch 48 ports 1GB which servers all the servers and all other switches connected to it too.
Should I create vlans on that main switch and then each switch which plugs into will be setup witch different subnet is this how shoud i do it ?
I am not big expert on vlans, do I create vlans on my main switch
Hello Vistek,
you can have 8 vlans deployed in all switches if needed
all devices must agree on the existance of these vlans in order to use them correctly.
This can be achieved by:
a) using VTP protocol with main switch and another switch in VTP server mode
b) or by using VTP mode transparent in all devices this requires configuration of the 8 vlans in each switch
Hope to help
Giuseppe
