experiencing delay in pinging to gateway ip
srikanth ath
Level 4
Level 4
hi all
I HAVE EXPERIENCED HUGE DELAY CONSTANTLY TO REACH GATEWAY.
mY NETWORK TOPO:
L2 switch(cisco 2960)------------fibre(200fts)-----------------L3switch(cisco 3750)--------Firewall(sonic wall)
Under L2 switch we have 30 users which is our branch office l2 switch is serving DHCP based on mac-binding.
L2 config:
interface vlan 99
ip add   10.10.14.2 255.255.255.0
DHcp:
ip dhcp pool branch office
network 10.10.14.0 255.255.255.0
default-router 10.10.14.1 255.255.255.0-----------------pointing to L3(3750) switch vlan99
dns-s erver 10.10.10.6
enabled dhcp snooping globally and ip source guard per interface and provide child pools for all the mac addresses.
L3 config:
interface vlan 99
ip add 10.10.14.1 255.255.255.0
L3switch# sh ip route
C       10.10.14.0/24 is directly connected, Vlan99
C       10.10.10.0/23 is directly connected, GigabitEthernet1/0/24
S*   0.0.0.0/0 [1/0] via 10.10.10.1
Here is my Output of ping to gateway from branch office:
C:\Users\srikanth.athelly>ping 10.10.10.1 -t
Pinging 10.10.10.1 with 32 bytes of data:
Reply from 10.10.10.1: bytes=32 time<1ms TTL=63
Reply from 10.10.10.1: bytes=32 time=36ms TTL=63
Reply from 10.10.10.1: bytes=32 time<38ms TTL=63
Reply from 10.10.10.1: bytes=32 time=38ms TTL=63
Reply from 10.10.10.1: bytes=32 time=31ms TTL=63
Reply from 10.10.10.1: bytes=32 time<25ms TTL=63
C:\Users\srikanth.athelly>tracert 10.10.10.1
Tracing route to 10.10.10.1 over a maximum of 30 hops
  1     6 ms    <1 ms    <1 ms  10.10.14.1
  2    <1 ms    <1 ms    <1 ms  10.10.10.1
Is dere anything i have to change here in topology wise or command wise
thanks for the help in advance
regards
sreek
nkarpysh
Can you ping same GW from L3 switch and compare trace results. I'm wondering if there are any CPU load on the GW which adds to the processing of the ICMP coming to it. Thus the new ping can help us to come closer to it eliminating part of infra.
Nik
HTH,
Niko
fb_webuser
Level 6
Level 6
why there is Ip given on vlan 99 on L2 switch? I think this should not be required since ur L3 has already SVI configured..
1.can u try to ping between user and check the latency ?
2. If that is good then check fibre between L2 and L3 .. I mean just try to check with high troughput ..
Lets try this then we will see further
Posted by WebUser Vishal Nijapkar
