Exporting PCAP
SeaLH
Frequent Visitor
Frequent Visitor
I am trying to run a packet capture on my Cisco WS-C3850-48P, firmware 16.3.b.
I seem to have gotten the actual capture working, but am just running into issues exporting. Here are my commands
monitor capture mypcap access-list CAP-FILTER
monitor capture mypcap limit duration 60
monitor capture mypcap interface gi1/0/1 both
monitor capture mypcap buffer circular size 10
monitor capture mypcap start
wait 60 seconds
monitor capture mypcap export location tftp://10.10.10.200/mypcap.pcap
Everything seems to work fine, the capture starts, and when I run the export command I get "Export Started Successfully" but nothing shows up on my tftp server. I have verified the tftp server works by transferring files to it with a tftp client, and I can ping the tftp server from the switch.
SeaLH
Frequent Visitor
Frequent Visitor
I got this working by just exporting to flash: then just doing the copy flash: tftp: command, worked fine.
7 Replies 7
balaji.bandi
where is the switch located compare to TFTP server.
For testing make you have PCAP any data, save Locally and upload to TFTP and test it ?
Also can you post below output :
monitor capture mypcap export  ?  (what option you have).
or try :
monitor capture mypcap export tftp://10.10.10.200/mypcap.pcap
Note :may be Limitation of the version of code running.
BB
I have tried a TFTP server on the same network as the switch, as well as one at an entirely different location.
How would I save the pcap locally?
location Location of the export file
status Check status of export
monitor capture mypcap export location flash:/yourfile.pcap
can you also post :
monitor capture mypcap export location ?
BB
Mark Elsen
 - Check the tftp server's logs , see if you can find any activity related to the receiving of pcap-data.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
SeaLH
Frequent Visitor
Frequent Visitor
There is none. I get plenty of informational messages when I was testing with a tftp client, but from the switch nothing.
SeaLH
Frequent Visitor
Frequent Visitor
glad you able to resolve the issue, appreciated your feedback.
BB
