Extended counter showing errors
sudip.acharya1
Level 3
Level 3
I have a 10yr HP blade system that seems to be having issues but need help narrowing down the the exact cause.
Sh Counters int gx/xx
** output omitted**
32 bit counters
10.                      ifOutDiscards = 3239159085
All port counters
24.                      ifOutDiscards = 3239159085
51.                        qos1Outlost = 3239159083
What can I look for to find the culprit?
How can I clear these counters? I tried Clear extended counters but that did not work.
Thanks in advance.
Chaitra Shree
Hi Sudip,
The above counters cannot be cleared. Do you see input queue drops,output drops, CRC/ input errors incrementing on the interface connecting the HP blade system ? ( under the show int <> command ). You will need to troubleshoot the issue depending on the counter which increments.
qos1Outlost counter signifies that less prioritized traffic is being dropped and logged under the counter for that queue. Do you have QoS configured on that interface ? If yes, check for QoS drops under the command "show queueing int <>". You may have to increase the resources available for QoS on that interface.
Chaitra
Hi Chaitra,
Under sho int, i do see the output drops:
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 35544
show queueing int
Interface GigabitEthernet8/48 queueing strategy:  Weighted Round-Robin
  Port QoS is enabled
  Port is untrusted
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:    5[queue 1]  25[queue 2]  70[queue 3]
    queue-limit ratios:      5[queue 1]  25[queue 2]  40[queue 3]  15[Pri Queue]
    queue tail-drop-thresholds
    1     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
      1    80[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
      2    80[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
      3    50[1] 60[2] 70[3] 80[4] 90[5] 100[6] 100[7] 100[8]
    queue random-detect-max-thresholds
      1    100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
      2    100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
      3    60[1] 70[2] 80[3] 90[4] 100[5] 100[6] 100[7] 100[8]
    WRED disabled queues:
    queue thresh cos-map
    1     1      1
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1      0
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1      4
    3     2      2
    3     3      3
    3     4      6
    3     5      7
    3     6
    3     7
    3     8
    4     1      5
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q8t]:
       01         WRR                 08
    WRR bandwidth ratios:  100[queue 1]
    queue-limit ratios:    100[queue 1]
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
  Packets dropped on Transmit:
    queue     dropped  [cos-map]
    1                        0  [1 ]
    2                    35544  [0 ]
    3                        0  [4 2 3 6 7 ]
    4                        0  [5 ]
  Packets dropped on Receive:
    BPDU packets:  0
    1                        0  [0 1 2 3 4 5 6 7 ]
These are the QoS settings we have aon the interface, which queue would need to be modified?
wrr-queue bandwidth 5 25 70
wrr-queue queue-limit 5 25 40
wrr-queue random-detect min-threshold 1 80 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 2 80 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 50 60 70 80 90 100 100 100
wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 3 60 70 80 90 100 100 100 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0
wrr-queue cos-map 3 1 4
wrr-queue cos-map 3 2 2
wrr-queue cos-map 3 3 3
wrr-queue cos-map 3 4 6
wrr-queue cos-map 3 5 7
Thanks.
Hi Sudip,
The output drops seen on the interface is same as the QoS drops seen on Queue 2 :
     1                        0  [1 ]
   2                    35544   [0 ]
    3                        0  [4 2 3 6 7 ]
     4                        0  [5 ]
So you need to look at queue 2.
The below link might be useful:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html
Chaitra
Thanks again.
