Extended ping is not happeining
chandru.j
Hi all,
In one of customer place problem is not able to browse.From the router i am able to ping but i am not able to do extended ping using my lan ip address. I checked all interface is up and i able to telnet from lan to lan interface of router .
What might be the problem.
Istvan_Rabai
Level 7
Level 7
Hi Chandrasekar,
If you are able to ping the destination from one source interface and you aren't able to ping from a different source interface on the same router, the problem is the following:
The route to source interface that you are not able to ping from is not known to the destination device.
Solution:
- Check if there is a route back from the destination device to the source interface.
- Check if the subnet of the source interface is advertised in a routing protocol at all.
- Check if the advertisement is not filtered anywhere along the way and the destination device receives this update.
Cheers:
Istvan
