extended ping with df bit set
dhalevi
Level 3
Level 3
hello,
I am trying to test the MTU between two 3750 switches I have in the lab.  I've set the MTU with the command "system mtu 9000" on both switches and rebooted.
The only connections on the switches are the gig ports connecting the two switches.  Each interface is  a member of vlan 1.
I am doing an extended ping.  I set the datagram size to 2000.  When the df bit is set the ping doesn't go through.  If the DF bit is not set the ping goes through.
The debug ip icmp shows,
4d00h: ICMP: dst (1.1.1.1): frag. needed and DF set.
Why is fragmentation needed when the MTU is set to 9000?
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0015.2b7d.0d01 (bia 0015.2b7d.0d01)
  MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
GigabitEthernet2/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0017.597f.7082 (bia 0017.597f.7082)
dot2#  ping ip
Target IP address: 1.1.1.1
Repeat count [5]:
Datagram size [100]: 2000
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]: yes
Validate reply data? [no]: yes
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: v
Loose, Strict, Record, Timestamp, Verbose[V]:
Sweep range of sizes [n]:
Sending 5, 2000-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Packet sent with the DF bit set
Reply data will be validated
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
Success rate is 0 percent (0/5)
thanks!
cciepending
Community Member
Please Check
https://supportforums.cisco.com/docs/DOC-2013
Please rate the helpful posts
hi,
I have followed this procedure on both switches already,
dot1#show system mtu
System MTU size is 1500 bytes
System Jumbo MTU size is 9000 bytes
Routing MTU size is 1500 bytes
dot1#
dot2#show system mtu
dot2#
First of all you need to tell if your ports are L3 or L2. You can see that your system
supports two MTU values;"system mtu jumbo" which stands for
MTU for GigabitEthernet port's L2 link and "system mtu routing" which
stands for MTU of routed packets for routed port.
System afaik does not support fragmentation between such 2 MTU value,
So the routed packets which received by gigabitethernet port will
be dropped if its size exceeds "system mtu routing" and ICMP dest
unreachable will not be sent.
So for further troubleshooting please paste the clear diagram and the ports config.
Nik
HTH,
Niko
dot1#sho run int gi1/0/1
Building configuration...
Hi Nikolay,
The interfaces are layer 2.  The only config i did besides the system mtu is I set an ip addess on vlan 1 on each switch and then connected the switches via the gig ports.
Current configuration : 38 bytes
interface GigabitEthernet1/0/1
end
dot2#show run int gi2/0/2
interface GigabitEthernet2/0/2
end
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
dot1             Gig 2/0/2         163              S I   WS-C3750- Gig 1/0/1
dot2#
