FA0/0 state detection
markbowman
Can I shutdown an interface if only 'transmit' side is bad? For ex., we have 2 switches connected with fiber and if we had trouble with one side of the fiber (transmit) side, the eigrp traffic in the router will not reroute traffic because it sees the correct route in the route table. It sees the correct route because the 'receive' from the far end switch is working.
I want the interface to shutdown if either transmit/receive is not working.
dominic.caron
Level 5
Level 5
You need to configure UDLD
here the link if the switch is a 6500
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/udld.html
You'll find similar chapters in other switch configuration guide.
Please rate helpful post.
dominic.caron
Level 5
Level 5
This is what we were looking for. We will try it out. Thanks.
