facing problem with 8 port switch ?
tariq_jamal08
I am facing problem with one 8 port switch ..when ever I am connecting with this switch 3-4 PCs after some time its showing error disable port.
I already checked with another port with same PCs. Its happening the same thing. I tried with different switch also. Its showing the same.
Need useful suggestion to retify the problem .
andrew.prince
Level 10
Level 10
What is the error disable reason the switch reports?
Actually, its disable from the main switch ...and its stop to work ....!!
Do you have any port security enabled on the port to which you are connecting the client to?
-Vijay
