L3 multicasting not working
All,
Can you please help with the following
We plan to implement multicasting on our network where the sourec and destination are going to be in different vlans.
I have a test 3750 switch, Layer two multicast works fine, when I place the source and destiantion in different VLan it fails
ip routing
ip multicast-routing distributed
interface Vlan3  (destination)
ip address 10.2.2.1 255.255.255.0
ip pim dense-mode
end
interface Vlan4    (source for mulitcast VLC)
ip address 10.3.3.1 255.255.255.0
ip pim dense-mode
end
Application used for testing = VLC  (239.255.100.100)
Sh ip mroute
(*, 239.255.255.250), 00:44:34/00:02:24, RP 0.0.0.0, flags: DC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan3, Forward/Dense, 00:07:56/00:00:00
    Vlan4, Forward/Dense, 00:44:34/00:00:00
(*, 239.255.100.100), 00:44:37/00:02:48, RP 0.0.0.0, flags: DC
    Vlan3, Forward/Dense, 00:00:11/00:00:00
(*, 224.0.1.40), 00:44:38/00:02:17, RP 0.0.0.0, flags: DCL
    Vlan4, Forward/Dense, 00:44:38/00:00:00
Any help is much appreciated
Kind Regards,
Zee
7 Replies 7
Reza Sharifi
Hi Zee,
Can you also turn on ip igmp snooping for both vlans and test again?
ip igmp snooping vlan 3
ip igmp snooping vlan 4
Hi Reza,
IGMP snooping is enabled on both vlan vlans
Vlan 3:
IGMP snooping                       : Enabled
IGMPv2 immediate leave              : Disabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp    (not sure if this is correct)
Last Member Query Interval          : 1000
CGMP interoperability mode          : IGMP_ONLY
Vlan 4:
Kind Regards,
Zee
Hi Zee,
When you configure VLC, there is an area where you have to specify the TTL, make sure that number is 2 or 3 and not 1.
than test again
I have tried using TTL as 2 and 3 but no luck please see screenn shot for details
Kind Regards,
Zee
Ok, this look good.
What license level do you installed on this switch
sh lice
forgot to add this to my previous post but
To run layer-3 multicast, you need IP services license
IP Services: Includes IP Base and enables  advanced IPv4/IPv6 Layer 3 routing such as EIGRP, Open Shortest Path  First (OSPF), WCCP, VRF-lite, PBR, and IPv4 multicast routing.
Hi Reza,
I am using following image its ip services
System image file is "flash:/c3750-ipservicesk9-mz.122-25.SEB4.bin"
following output for sh license
Switch#sh lic?
% Unrecognized command
Switch#sh lic
