fail module after update ROMMON
Breszko Daniel
I have problem with my WS-C4500X-32.
After update ROMMON to firmwareupgradeallK10-150_1r_SG15.SPA my module is Fail.
Supervisor don't see any Gbic inserted inplug in interfaces (No XCVR).
Some one have any ideas to fix it ?
Switch#sh module
Chassis Type : WS-C4500X-32
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 32 4500X-32 10GE (SFP+) WS-C4500X-32 JAEXXXXXXX
M MAC addresses Hw Fw Sw Status
1 e4aa.5dab.6240 to e4aa.5dab.625f 2.0 15.0(1r)SG15 03.09.02.E Ok
Switch#show diagnostic result module 1
Current bootup diagnostic level: minimal
module 1: SerialNo : JAE1938075E
Overall Diagnostic Result for module 1 : MINOR ERROR
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1) supervisor-bootup ---------------> .
2) linecard-online-diag ------------> F
3) stub-rx-errors ------------------> .
4) supervisor-rx-errors ------------> .
Switch#show diagnostic result module 1 detail
module 1: SerialNo : JAEXXXXX
___________________________________________________________________________
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 1
Last test testing type ------> n/a
Last test execution time ----> Feb 06 2019 11:54:44
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> Feb 06 2019 11:54:44
Total failure count ---------> 0
Consecutive failure count ---> 0
Power-On-Self-Test Results for ACTIVE Supervisor
prod: WS-C4500X-32 part: 73-14959-07 serial: JAEXXXXX
Power-on-self-test for Module 1: WS-C4500X-32
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
Module 1 Passed
Error code ------------------> 1 (DIAG_FAILURE)
First test failure time -----> Feb 06 2019 11:54:44
Last test failure time ------> Feb 06 2019 11:54:44
Last test pass time ---------> n/a
Total failure count ---------> 1
Consecutive failure count ---> 1
Slot Ports Card Type Diag Status Diag Details
1 32 4500X-32 10GE (SFP+) Skipped Packet memory
Total Failure Component
Detailed Status
. = Pass U = Unknown
L = Loopback failure S = Stub failure
P = Port failure
E = SEEPROM failure G = GBIC integrity check failure
Ports 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Ports 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Total run count -------------> 20
Last test testing type ------> Health Monitoring
Last test execution time ----> Feb 06 2019 12:13:45
Last test pass time ---------> Feb 06 2019 12:13:45
7 Replies 7
Mark Malone
so since upgarde no gbics are been seen by the switch is that correct ?
Are they seen in show inventory ?
Yes, now i have inserted 20x Gbic 10GB/1GB and i dont see any.
In invertory i have only this:
Switch# sh inv
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4500X-32 2 slot switch "
PID: , VID: , SN: JAXXXXX
NAME: "Supervisor(slot 1)", DESCR: "4500X-32 10GE (SFP+)"
PID: WS-C4500X-32 , VID: V05 , SN: JAEXXXXX
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 750W )"
PID: C4KX-PWR-750AC-R , VID: V01 , SN: ART1852X1NJ
Hi have you tried a fresh reboot since then ?
did you upgrade ROM for a particular reason can you roll back ?
Thank you for your response,
I had to update Rommon to the latest available version (SG15), I downloaded the SG11 version and installed it, but the problem is still the same.
Leo Laohoo
Contact TAC and organize for an RMA.
I checked the state of these ports and I am surprised that they are able to (RunModeFrozen), in good switch are (RunModeOperating).
Switch#sh platform chassis pluggable
GalChassisVp
  slot 0: state=8,1,11 ElbCardType 402 GalModuleType 3
GalK5ModuleVpSlot : type( GalModuleVpTypeGlm )
GalK5DriverMan(0): runMode( 4 ) state( GalK5DriverManStateReady )
prevState( GalK5DriverManStateSuccess )  gldMinor( 49 )  Retries( 0 )
SR-Register( 0x00000101 )  gldMajorVersion( 0x01 )  cardRevision( 0x01 )
SR-RegisterValid( true )  driverType( Native )  SpiRomSize( 33554432 )
GalGlmLinecardVp(0:N) ElbCardType 402, GalModuleType 3,
Config RunModeOperating, Op RunModeOperating, uplinkMode SupervisorUplinkK2Like, redundantMode SupervisorLocalNonRedundant
 System StatValue count 913
Bringup timeout: WaitAllOperating
Linecard 0 timeout: Complete
Linecard 1 timeout: WaitAllOtherOperating
Interrupts handled=0
Spurious linecard interrupts: total=0, consecutive=0, max consecutive=0
EpmPluggableGroup(0:N) managing 32 pluggables, RunModeFrozen
received changed notifies=0, rxLoss notifies=0
    ReviewRunTimeMax=6000, ReviewRunTimeExpected=1000
    ReviewPeriod=1000000 MaxSubReviews=0 DOM interval=30000000
Review pluggables                  last 5 seconds   last minute     last hour
    Events per second                     0              0             0
Total : 0
    Te1/1      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/2      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/3      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/4      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/5      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/6      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/7      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/8      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/9      RunModeFrozen        State=EmptyHole            Changed=False
    Te1/10     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/11     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/12     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/13     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/14     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/15     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/16     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/17     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/18     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/19     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/20     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/21     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/22     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/23     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/24     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/25     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/26     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/27     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/28     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/29     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/30     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/31     RunModeFrozen        State=EmptyHole            Changed=False
    Te1/32     RunModeFrozen        State=EmptyHole            Changed=False
GalGlmLinecardMan(0:N/0) : ElbCardType 402 Config RunModeOperating, Op RunModeOperating, Status Ok
GalGlmLinecardMan(0:N/1) : ElbCardType 403 Config RunModeOperating, Op RunModeOperating, Status Ok
GalGlmLoopbackDiagMan(1)
GalGlmStubDiagMan(1/1) PPPP
GalGlmStubDiagMan(1/2) PPPP
GalGlmStubDiagMan(1/3) PPPP
GalGlmStubDiagMan(1/4) PPPP
PluggableLinecard(0:N), Config RunModeOperating, Op RunModeOperating
GlmEdcControllerMan(0) managing 32 Edcs, speaking S2w100KHzSingleMaster
RunMode=RunModeOperating, opRunMode=RunModeOperating
    Edc   Config Reg   Status Reg
    0    0x00000000   0x0000000A
    1    0x00000000   0x0000000A
    2    0x00000000   0x0000000A
    3    0x00000000   0x0000000A
    4    0x00000000   0x0000000A
    5    0x00000000   0x0000000A
    6    0x00000000   0x0000000A
    7    0x00000000   0x0000000A
    8    0x00000000   0x0000000A
    9    0x00000000   0x0000000A
    10   0x00000000   0x0000000A
    11   0x00000000   0x0000000A
    12   0x00000000   0x0000000A
    13   0x00000000   0x0000000A
    14   0x00000000   0x0000000A
    15   0x00000000   0x0000000A
    16   0x00000000   0x0000000A
    17   0x00000000   0x0000000A
    18   0x00000000   0x0000000A
    19   0x00000000   0x0000000A
    20   0x00000000   0x0000000A
    21   0x00000000   0x0000000A
    22   0x00000000   0x0000000A
    23   0x00000000   0x0000000A
    24   0x00000000   0x0000000A
    25   0x00000000   0x0000000A
    26   0x00000000   0x0000000A
    27   0x00000000   0x0000000A
    28   0x00000000   0x0000000A
    29   0x00000000   0x0000000A
    30   0x00000000   0x0000000A
    31   0x00000000   0x0000000A
Lasi interrupts received=0, handlingInterrupt=False
Vsi errors:    total=0, last=Null
Vsi failures:  consecutive=0, max consecutive=0
Vsi successes: consecutive=318, max consecutive=318
 EDC PHY ID Model ( 15 ) Version ( 4 )
edcControllerMan_(0:N), numEdcGroups( 8 ), numEdcPorts ( 32 ), RunMode( RunModeOperating ), OpRunMode( RunModeOperating )
  ConfigEdcType( 3 ), OpEdcType( 3 )
edcControllerMan_(0:N) EthEdcBcm84754Man( 0 ), RunMode( RunModeOperating ), OpRunMode( RunModeOperating )
EdcInitState: 42 EdcUcodeChecksum: ( 0x600D ) General2Reg: ( 0x12C )
EdcBcm(edcControllerMan_(0:N) EthEdcBcm84754Man( 0 )) in 10GModeComplete
  Ucode version Reg ( 0x00 )
  General 2 Reg(1.CA1A)=0x00
  EDC chip revision Reg : 0x0
edcControllerMan_(0:N) EthEdcBcm84754Man( 0 ) LinkControllerMan, RunMode( 4 )
PreviousReviewLinkState( Null ), CurrentReviewLinkState( Null )
NegotiationStatus( 1 )
    Reg(7.FFE0)=0x00 Reg(7.FFE4)=0x00
    Reg(7.FFE5)=0x00, Cached Reg(7.FFE5)=0x00
    LinkStatusReg=000
    Pmd10GStatus2Reg_(1.000a)=0x00 Pcs10GStatusReg(3.0020)=0x00
    Pmd10GOpticsDigitalControlReg_(1.cd09)=0x00
    Pmd10GStatus1Reg_(1.01)=0x00 Pmd10GStatus2Reg_(1.08)=0x00
    Pcs10GStatus1Reg_(3.01)=0x00 Pcs10GStatus2Reg_(3.08)=0x00
Configuration Params:
Config: ConfigurationModeDisabled FlowControlModes[] LineSpeeds[]
        DuplexModes[] ClockModeNull Unknown
        LoopbackOff FaultIndicationNone 0 Debounce0ms Efficient Energy Ethernet N/A
 Link Downshift Feature(for Mgig ports) Enabled
Operational Params:
Ops:    LinkDown FlowControlModeNull LineSpeedNull DuplexNull
        ClockModeNull FaultIndicationNone NegotiationErrorNone EfficientEthernet:  N/A
        #link downs: 0
OpConfigMode: ConfigurationModeDisabled
Debounce:
  Triggered: 0  Debounced: 0
edcControllerMan_(0:N) EthEdcSfpCtrlMan( 0 ) managing 1 sfps, speaking Mdio1MHz
 State(StateWaitForNextReview), SubState(SubStateMonitor)
 InterruptState(InterruptStateNull), TotalInt( 0 ) InitRetry( 1 )
TwoWireDmaSelRegRead (1.8800) = 0x00
PmaPmdControlReg    (1.0000) = 0x00
Rx Alarm Control Reg(1.9000) = 0x24
Tx Alarm Control Reg(1.9001) = 0x00
Lasi Control Reg    (1.9002) = 0x04
Rx Alarm Status Reg (1.9003) = 0x401C
Lasi Status Reg     (1.9005) = 0x0C
Pmd Control Reg     (1.C800) = 0x3F80
Pmd Status Reg      (1.C804) = 0x8008
Optical Config Reg  (1.C8E4) = 0x3F
General2 Reg        (1.CA1A) = 0x00
Mii Control Reg     (7.FFE0) = 0x00
Misc2Reg            (7.8309) = 0x00
    changes detected=0, changes notified=0, rxLoss detected=0 lasi interrupt detected=0
    read cache initialized(False), stale(True), dirty(True)
Vsi successes: consecutive=28, max consecutive=28
edcControllerMan_(0:N) EthEdcBcm84754Man( 1 ), RunMode( RunModeOperating ), OpRunMode( RunModeOperating )
EdcBcm(edcControllerMan_(0:N) EthEdcBcm84754Man( 1 )) in 10GModeComplete
