12-05-2016 11:34 AM - edited 03-08-2019 08:26 AM
I had a series of power failures over the night, now when the 2960s boot it stops.
Anything I can do?
12-05-2016 11:58 AM
There is nothing to be done except contact Cisco TAC and request for RMA.
12-05-2016 12:32 PM
So what if I try and re-firmware it?
12-05-2016 01:00 PM
You can try and load the IOS using Xmodem if that does not help than you would have to do what Leo said.
here is a link for instructions
https://supportforums.cisco.com/blog/151336/loading-ios-switch-xmodem
12-05-2016 01:42 PM
You could try, but I doubt it'll work. The power surge must've fried flash memory.
Please note that the 2960S is covered under Cisco's Limited Lifetime Warranty.
