Port-based authentication
gaelfabrice
having this error while trying to config dot1x on physical port
ASW1(config)#interface fastEthernet 0/3
ASW1(config-if)#dot&
ASW1(config-if)#dot1
ASW1(config-if)#dot1x ?
% Unrecognized command
how to make it works plz, im trying to configure port-based authentication on switch  3560
Mark Malone
Make sure switchport mode access is enabled under the interface and you are running AAA
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_55_se/configuration/guide/3560_scg/sw8021x.html#31098
have already config the port mode to access and  thx i have used the alternative command
authentication port-control i dont know why dot1x port-control doesnt works
