Failed Sensor messages on WS-C6509-E
chamika_sooriyabandara1
Community Member
Hi All,
We have WS-C6509-E which is running on Version 12.2(17r)SX6.
it was giving following message on one of the module.
Status Information:  (module 5 fan-upgrade required Sensor: sensor unavailable), (module 1 insufficient cooling Sensor: sensor unavailable), (module 5 insufficient cooling Sensor: sensor unavailable), (Te1/4 Receive Power Sensor: sensor unavailable), (Te1/8 Transmit Power Sensor: sensor unavailable), (module 7 insufficient cooling Sensor: sensor unavailable), (Te1/8 Receive Power Sensor: sensor unavailable), (Te1/7 Transmit Power Sensor: sensor unavailable), (Te1/7 Receive Power Sensor: sensor unavailable), (Te1/4 Transmit Power Sensor: sensor unavailable), (module 3 insufficient cooling Sensor: sensor unavailable) : 69/80 sensors reported OK (22 sensors using thresholds) : CRITICAL
Does anyone know the workaround to resolve this?
Thank you in-advance.
Hi ,
Did you see this under show log on switch or under some monitoring tool?
What is the output sh env on switch?
sh env
Madhu
If you dont see anything on the logs on the switch or under enviornement alarms, you may need to check the monitoring tool. It could be a false alert also.
However first check the sh env on switch itslef to ensure no problem.
Madhu.
****Kindly rate all useful posts*****
Hi Madhu,
Thanks for this info. Here is the show environment output
------------------ show environment ------------------
environmental alarms:
  no alarms
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6509-E-FAN
  fan-tray 1 mode: High-power
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 34C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 29C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 28C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-mode: high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-mode: high
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 44C
  module 1 inlet temperature: 31C
  module 1 aux-1 temperature: 41C
  module 1 aux-2 temperature: 35C
  module 1 asic-1 temperature: 68C
  module 1 asic-2 temperature: 67C
  module 1 EARL outlet temperature: 36C
  module 1 EARL inlet temperature: 32C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 28C
  module 3 inlet temperature: 26C
  module 3 device-1 temperature: 27C
  module 3 device-2 temperature: 30C
  module 3 EARL outlet temperature: 32C
  module 3 EARL inlet temperature: 30C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 37C
  module 5 inlet temperature: 27C
  module 5 device-1 temperature: 30C
  module 5 device-2 temperature: 33C
  module 5 asic-1 temperature: 57C
  module 5 asic-3 temperature: 40C
  module 5 asic-4 temperature: 53C
  module 5 RP outlet temperature: 29C
  module 5 RP inlet temperature: 30C
  module 5 EARL outlet temperature: 32C
  module 5 EARL inlet temperature: 27C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 31C
  module 7 inlet temperature: 27C
chassis connector rating: 1302.00 Watts (31.00 Amps @ 42V)
chassis auxiliary connector rating: 2016.00 Watts (48.00 Amps @ 42V)
module 1
  module 1 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 1 power consumption:  444.36 Watts (10.58 Amps @ 42V)
module 3
  module 3 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 3 power consumption:  162.96 Watts ( 3.88 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption:  338.10 Watts ( 8.05 Amps @ 42V)
module 7
  module 7 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 7 power consumption:  325.50 Watts ( 7.75 Amps @ 42V)
chassis per slot cooling capacity: 94 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 84 cfm
  module 3 cooling requirement: 70 cfm
  module 5 cooling requirement: 35 cfm
  module 7 cooling requirement: 70 cfm
and yes we have captured this on Monitoring tool and its not showing up on above output.
So do you reckon this a false alarm?
Thanks & Regards,
Chamika
Muhammad Nasir
Community Member
PRTG displays these error messages for 6513E:
Insufficient Cool Sensor
-15 dBm is below the error limit of -12 dBm
Thanks.
