Showing results forĀ
Search instead forĀ
Did you mean:Ā
failing to assigning ip address successfully.
jahedhussein
i have been tasked with creating an internetwork with different workgroups. i am currently trying to connect a WAN link router to a switch but i am having issues when assigning the switch an ip address. when i try to do so, i get the error message "133.221.192.49 255.255.255.0 overlaps with GigabitEthernet6/0".
i have sat at this issue for the past almost 2 hours, and cannot get my head around it. i would appreciate any help.
p.s. my explanation is very brief but i tried to make it as simple as possible.
post the running configurations (sh run) of both the router and the switch, and indicate which interfaces are used to connect them.
Martin L
Every L3 device has simple rule of "each of my interfaces must be connected to a different network/subnet".  This rule is always applied to the same device and same routing instance (as u could have multiple VRFs)
So, error "133.221.192.49 255.255.255.0 overlaps with GigabitEthernet6/0" simply says there is another  IP already configured on subnet 133.221.192.x /24
what is current IP of GigabitEthernet6/0 ? or all your IPs , use show ip interface brief
Regards, ML
**Please Rate All Helpful Responses **
