Port channels on a fex interface
ryancisco01
we have cisco 5k's with fex's attached:
N5k1 -> fex101
-vpc peer link-
N5k2 -> fex 102
What I have now done is tried to configure a vpc off the two fex's toward a server, the interfaces are up but the port channel refuses to come up, just wondering, is this config supported since a vpc has to be defined from the nexus to the fex? essentially its a new vpc inside another vpc? It took the commands without any complaints.
Currently shows:
port-channel50 is down (No operational members) vPC Status: Down, vPC number: 50 [packets forwarded via vPC peer-link]
10 Replies 10
balaji.bandi
First question is the FEX are Dual Homed ? (this means FEX 101 connected to Nexus 5K 1 and 5K2) if not that not going to work.
post the config.
or here is example you need to seup for the Server to use port-channel.
Nexus 5K1 and 52 config :
fex 101
pinning max-links 1
description "XXXXXXXXXX"
slot 101
provision model N2K-C2248TP-E-1GE
fex 102
pinning max-links 1
slot 102
interface Ethernet1/YY
description *** Uplink1 : FEX 101 ***
switchport mode fex-fabric
fex associate 101
channel-group 101
interface port-channel101
fex associate 101
vpc 101
interface Ethernet1/XX
description *** Uplink1 : FEX 102 ***
fex associate 102
channel-group 102
interface port-channel102
fex associate 102
vpc 102
This config for server
interface Ethernet 101/1/1
no cdp enable
switchport access vlan XXXX
spanning-tree port type edge
channel-group 14 mode active
interface Ethernet 102/1/1
no cdp enable
interface port-channel14
no lacp suspend-individual
spanning-tree guard root
BB
Hi thanks for the reply,
no the fex's are single homed, fex101 connects to N5k1 only and fex102 connects only to Nk52
The rest of the config I am using matches the config you have provided above.
Can you advise if there is any document that shows this limitation? I have just found a document which seems to indicate this is supported -
https://www.cisco.com/c/en/us/support/docs/switches/nexus-2000-series-fabric-extenders/200363-nexus-2000-fabric-extenders-supported-un.html#anc7
Is there a s/w limitation perhaps? I am currently on 6.0(2)N2(5)
If each FEX is attached to only one switch, you don't need any vPC.
You only need a Portchannel on the switch and the server-side configured with mode "on or LACP".
The other option would be to simply connect the server to 2 FEXs using a trunk or access port (no portchannel) and configure the server-side with high availability.
I have tried Po50 with and without vPC config on both nexus, both times it refuses to come up same error - no operational members
The link from the nexus to the fex:
description To FEX
fex associate 101
link between the nexus':
switchport mode trunk
vpc 1
Link to the server:
interface port-channel50
no lacp graceful-convergence
switchport access vlan 1
vpc 50
interface Ethernet101/1/2
channel-group 50 mode active
(The config is replicated on nexus 2)
Any other reason this might not be working?
The link between Nexus is missing this command:
vpc peer-link
good spotting, unfortunately that was my mistake, po1 is the non vpc trunk and po14 is the vpc peer:
spanning-tree port type network
vpc peer-link
also to add context, I have several vpcs working fine where the links are physically attached to the 5k, none work on the fex.
I have noticed one command missing which I saw in one example online, the port channel to the fex does not have a vpc specified, is that required? I have other active ports on the fex so bit hesitant to just try and put it on
eg should it be:
description To FEX
fex associate 101
vpc 101
No, if each fex is connected to only one parent switch, there is no need for that command (vpc xx).
If the FEX not dual homed your confiiguration seems to be ok.
in regards to port-channel to server, is the server card support LACP ? if not as suggested go with access port, if one fails other one able to take over load - based on windows server config.
BB
pman
Attaches a configuration to your situation:
http://vpackets.net/2014/10/vpc-order-of-operations/
thank you that confirms at least what we are doing should work.
we have the team checking the server for any issues now. They definitely support lacp, we will attempt to bring them up as individual links now to determine where the issues lays.
