failover using spanning tree
carl_townshend
Hi all, im trying to failover my 2 asa's by using spanning tree, creating a loop between them, is this possible ?
5 Replies 5
Amit Singh
Carl,
Are you trying to set a LAN based fail-over or connecting the ASA's back-back using the LAN cable? Please let us know more on the design that you are trying to setup.
-amit singh
thanks for replying amit, basically I have 2 asa 5505, in transparent mode, I want 1 of them to be redudant, I dont think they support failover so I was going to create a loop somehow, so it blocks on of the lan ports, or is there another way ?
please help
Carl,
I think you can configure LAN-based fail-over on the firewall. Stateful failover is not supported on ASA5505.
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/general/failover.htm#wp1058096
-amit singh
I had a read and I Dont think this will help, can anyone help me out on this ?
cheers
Carl,
Sorry for the information provided above, I have just realized the ASA5505 doesnot support fail-over on it. Let me know the lan connectivity design you are trying to set.
-amit singh
