Fallback OS Catalyst 3850 Series
KedaiMimih
Hi everyone,
we will plan to upgrade the Catalyst 3850 Series OS, the OS version 16.6.4a is now installed and we want to upgrade to 16.12.11,
I have found how to install/upgrade in the attached link.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/release_notes/ol-16-3-3850.html
However, we had difficulty finding documents on how to fall back to the original OS, and we tried to find the old OS on our device
file (.bin) not found.
Please help, how do I fallback the OS to everything?
thanks
Mohamad Lukman
10 Replies 10
johnlloyd_13
Level 9
Level 9
hi,
you can "downgrade" using the #request platform software package install privilege exec command. see link below:
https://wannabelab.blogspot.com/2023/04/cisco-3850-switch-ios-xe-downgrade-16x.html
just file transfer the target lower version IOS-XE via USB or FTP/TFTP.
KedaiMimih
The method is exactly the same as installing the upgrade, right?
Upgrades
copy tftp://192.168.1.10/os-upgrade.bin flash:os-upgrade.bin
Install
request platform software package install switch all files flash:os-upgrade.bin new auto-copy
Downgrade
copy tftp://192.168.1.10/os-downgrade.bin flash:os-downgrade.bin
Install
request platform software package install switch all files flash:os-downgrade.bin new auto-copy
Like this?
Mohamad Lukman
Leo Laohoo
Post the complete output to the command "dir".
If the Install Mode was done correctly, there should be two "packages.conf" files:
1.  First packages.conf file will point to the new firmware.
2.  Second packages.conf file, maybe called packages.conf.00-, will point to the old firmware.
Fall-back is easy:
1.  Rename "packages.conf" to something else, like "package.conf.bak".
2.  Rename "packages.conf.00-" to "packages.conf".
3.  Check the contents of "packages.conf" to see what firmware it will boot:  more flash:packages.conf | begin for NOVA
4.  If all looks correct, reboot.
KedaiMimih
okay, thank you for the information provided,
how to rename "packages.conf" to "packages.conf.bak"?
just rename packages.conf, then reload, right?
Mohamad Lukman
rename flash:packages.conf flash:packages.conf.bak
KedaiMimih
==Downgrade==
LAB# dir flash:
packages.conf (new version)
packages.conf.xx (old version)
LAB# rename flash:packages.conf(new version) flash:packages.conf.bak
LAB# rename flash:packages.conf.xx (old version) flash:packages.conf
LAB#show boot
Switch 1
Current Boot Variables:
BOOT variable does not exist
Boot Variables on next reload:
BOOT variable = flash:packages.conf
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
LAB#
LAB#reload
Like this, right?
Mohamad Lukman
Post the complete output to the command "more flash:packages.conf | begin for NOVA".
Hi Leo,
we have another new case, the current status of the 3850 switch is 2 switch mode-stack, and the upgrade plan will be to remove stack-mode, and will
upgrade per switch, which is our question;
1. Is there any configuration for routing, VLAN, etc. on the 2 switches after removing stack-mode?
2. Can you share with us how to remove stack-mode on Switch3850?
Mohamad Lukman
conf t
 no switch 2 provision <MODEL>
end
  1. Power down switch 2.
  2. Remove stacking cable from switch 1 and switch 2.
  3. Remove switch 2 from the rack
  4. Renumber switch 2 to switch 1 (for future deployment) & wipe the config or perform factory reset.
