Fast hello link for Dual-Active Detection
krishnadig
My query is regarding "exclude interfaces" in Dual-Active Detection.
Do I need to add the fast hello interfaces as part of dual-active exclude interfaces?
When a dual active scenario is detected, and primary chassis is in recovery mode - I get below output; is that normal?
Fast-hello dual-active detection enabled: Yes
Fast-hello dual-active interfaces:
Port       Local State    Peer Port    Remote State
Gi2/1/2    Link dn        -            -
show switch virtual dual-active summary
Pagp dual-active detection enabled: Yes
Bfd dual-active detection enabled: Yes
No interfaces excluded from shutdown in recovery mode
In dual-active recovery mode: No
From the output above i do not see any issue.
Hope it was useful and rate the posts if you find them useful. Please feel free to ask incase of any further questions.
Madhu.
Hello Krishna,
In dual active recovery mode, all the interfaces except the VSL links are shut down. There is no need to exclude the dual -active interface in excluded list.
Just to clarify looking at your outputs, i do need see the switch in recovery mode. So is the output taken after recovery is done ?
Hi Madhukrishnan,
Thanks for clarifying.
At the moment, the VSS is operating in normal mode & the output is below. Please advise if you see anything wrong..
show switch virtual dual fast-hello
Gi1/1/2 Link up Gi2/1/2 Link up
Madhu.
