Fastethernet 0/26 is suspended-no-linkbeat
cjsands61
I have a 2500 router connected by AUI / transeiver to a 1924 Switch (fa 0/26 port). Both have their ports running at half duplex. The router says the port is up and up but switch says the fastethernet port is suspended-no-linkbeat. I have reset both devices to out-of-the-box defaults and started over with new configs. The fa 0/26 port on switch says STP state is blocking but I can't get it to a forwarding state (if that is part of the problem). I'm just starting my studies for CCNA and I'm stumped here. I have tried researching that particular error message but cannot find anything that points me in the right direction for the solution. Any advice or input would be appreciatecd. Here is the output of show interface on the 1924:
FastEthernet 0/26 is Suspended-no-linkbeat
Hardware is Built-in 100Base-TX
Address is 0007.8541.9BDA
MTU 1500 bytes, BW 100000 Kbits
802.1d STP State: Blocking Forward Transitions: 0
Port monitoring: Disabled
Unknown unicast flooding: Enabled
Unregistered multicast flooding: Enabled
Description:
Duplex/Flow Control setting: Half duplex
Enhanced Congestion Control: Disabled
All other Receive/Transmit statistics are 0
Running Enterprise Edition Software Version V9.00.04
Here is output for ethernet0 on 2500:
Ethernet0 is up, line protocol is up
Hardware is Lance, address is 0010.7b80.90fd (bia 0010.7b80.90fd)
Internet address is 192.168.16.1/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input never, output 00:00:07, output hang never. All the other counters are 0
Running Cisco Internetwork Operating System Software
IOS (tm) 2500 Software (C2500-JS-L), Version 12.2(12a), RELEASE SOFTWARE (fc1)
I can supply more info if needed.
John Blakley
I would try setting the speed on your fa0/26 port to 10:
int fa0/26
speed 10
duplex half
Try setting the same way in the router.
HTH,
John
HTH, John *** Please rate all useful posts ***
