FastEthernet1/0 is up, line protocol is down. Please help!!!
cisco24x7
Level 6
Level 6
I have a Cisco 2610 with NM-1FE fast ethernet port.
this Fast Ethernet is connected to a Cisco 2960
on port g0/21. Port g0/21 is hard code to 100-full
duplex. The Cisco 2610 Fast ethernet interface
is also hard code to 100-full duplex. However,
on the Cisco 2610, it says that F1/0 is up but
line protocol is down. I performed several "shut"
and "no shutdown" on both the catalyst 2960 and
the Cisco 1FE interface, but the line protocol is
still down. Why? Can anyone help?
BGP_Trigger#sh run int f1/0
Building configuration...
Current configuration : 97 bytes
interface FastEthernet1/0
ip address 192.168.1.9 255.255.255.240
speed 100
full-duplex
end
BGP_Trigger#
BGP_Trigger#sh int f1/0
Hardware is AmdFE, address is 0001.961f.1b70 (bia 0001.961f.1b70)
Internet address is 192.168.1.9/28
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
BGP_Trigger#ping 192.168.1.9
Sending 5, 100-byte ICMP Echos to 192.168.1.9, timeout is 2 seconds:
Success rate is 0 percent (0/5)
BGP_Trigger#
C2960#sh run int g0/21
Current configuration : 160 bytes
interface GigabitEthernet0/21
description BGP_Trigger F1/0
switchport access vlan 666
media-type rj45
speed 100
duplex full
spanning-tree portfast
end
C2960#
C2960#sh mac address-table dynamic interface g0/21
Mac Address Table
Vlan Mac Address Type Ports
666 0001.961f.1b70 DYNAMIC Gi0/21
Total Mac Addresses for this criterion: 1
C2960#
C2960#sh int g0/21
GigabitEthernet0/21 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0019.551b.d615 (bia 0019.551b.d615)
Description: BGP_Trigger F1/0
Keepalive not set
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
12 Replies 12
Edison Ortiz
Not sure if you've tried this:
1) Change the speed/duplex to auto/auto on both ends
2) Try another patch cable
3) Try another switchport in the 2960
4) Try reseating the module in the 2610 router
5) Upgrade the IOS code in the 2610
6) Get another NM-1FE
HTH,
__
Edison.
1- yes (still have issue)
2- yes (this port is working with another Unix box so the port is good)
3- yes (still have issue)
4- It is running the code known to good. I use this code in production, as recommended by Cisco TAC
5- Code on 2960 is good as well, as recommended by Cisco TAC
6- I do not have a spare NM-1FE
CCIE Security
c2600-ik9o3s3-mz.123-24a.bin On C2610
c2960-lanbasek9-mz.122-25.SEE4.bin
David
This is pretty interesting. I note that there is communication over the link since the switch has learned the MAC of the router:
Mac Address Table
I wonder if there could be an issue with VLAN 666? Are there other ports in VLAN 666 that are working? Do the symptoms change if you put that port into a different VLAN with known working ports?
Rick
Rick
Rick,
I have a couple of Unix machines on VLAN 666
and they are working fine. Furthermore, one
of the firewall interfaces is also in VLAN 666
as well. All devices on VLAN 666 point to the
firewall as the default gateway, except this
NM-1FE interface on the 2610.
I also move the NM-1FE to another vlan 667 but
it does not work either.
By the way, I heard that you will be giving
some presentations at Cisco facility in
Herndon at the begining of March, correct?
David
David
I see the problem - but am still not sure what is causing it. In the show interface output from the switch:
C2960#sh int g0/21
Keepalive not set
If the switch port has keepalive not set then its interface will be up/up (as it is) and the neighbor interface will be up/down. I am not sure why keepalive is disabled on the switch but that is the issue.
Yes I will be doing a presentation at Cisco in Herndon in early March. Will I see you there?
Rick
Rick
Rick,
I disabled "keepalive" on the switchport for
testing 'cause I am getting desperate -:(
I re-enabled keepalive back on but same issue.
problem is that I am a firewall/security person so troubleshooting layer-1/layer-2 is
not my strong point -:(
Yes, I will be in Herndon that week. Looking
forward to your presentation.
C2960#clear mac address-table dynamic
C2960#sh int g0/21
Last input 00:02:21, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 3000 bits/sec, 6 packets/sec
2335 packets input, 149746 bytes, 0 no buffer
Received 87 broadcasts (0 multicast)
0 watchdog, 8 multicast, 0 pause input
213475 packets output, 16444884 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
C2960#sh mac address-table dynamic int g0/21
Mac Address Table
C2960#
Try these suggestions:
1) Disable keepalive at both devices
or
2) Try setting the speed to 10/FD
HTH,
__
Edison.
David
I thought that I had found it but that is not the case :(
Here is my current thought and suggestion:
- the switch has learned the MAC from the router which demonstrates that there is some physical communication from router to switch.
- the show interface counters on the switch may not represent the current situation:
can you clear the counters, let it run for a bit and post the output of a new show interface?
- can you also clear the counters on the router, let it run a bit and post the output of show interface?
- if data is flowing from router to switch but apparently not from switch to router then it suggests a possible problem with the transmit side from the switch, a possible problem with the cable connecting them (I have more than once seen a bad pin in a cable produce the symptom of one way communication), or a possible problem with the receive side of the router. If you temporarily move the router connection to a different switch port that should check out the switch possibility. If you change the cable connecting the switch and router that should check out the cable possibility. If you take the existing port on the switch and the existing cable and connect it to something else and it works that would point to a problem on the receive of the router.
[edit] re-reading the entire thread I see that you have apparently already tried some of the things that I suggest.
Rick
Rick
Rick,
All of your suggestions are valid. Thanks.
Here is my current situation:
1- cable is good. I've tested and verified
that the cable is good and works with a
Linux workstation,
2- the switchport is good. The switchport
is tested and verified with a Linux machine
on VLAN666, on the same port that the Cisco
2610 NM-1FE is connected to.
Therefore, I can safely eliminate both the
switchport and the cable because it is tested
and verified that it works with other
devices.
What I did next:
1- remove the NM-1FE from the Cisco 2610. I
then remove the Cisco 2610 altogether.
2- insert the NM-1FE into a Cisco 2621 router
running the same IOS code as the C2610. I
then assign the same ip address to the
interface F1/0. Last step, I connected
interface F1/0 into the same catalyst 2960 switch on port g0/21. To my suprise,
everything works. It does not matter if
I set the interface F1/0 to 100/full or
auto/auto or 100/full or auto/auto on the
catalyst 2960. Everything just works. Not
only it works on the Cisco 2621, it also
works on the Cisco 3620 as well.
It makes me wonder. Does Cisco 2610 support
NM-1FE module? I've tried it on three
different Cisco 2610 with the same result.
In other words, it does not work. It is
possible but very unlikely, that all four
Cisco 2610 have a bad NM slot.
After playing with the speed/duplex a little
bit more, this is what I've found out:
Cisco 2610 can only support, at most, 10-full
on the NM-1FE. If you hard code the F1/0
to 100-full, it will NOT work. You can use
100-full if you use the NM-1FE on Cisco 2621 or Cisco 3640. Just test and verify it.
In other words, I can only utilize 10-full
on the NM-1FE if that card is used on the
cisco 2610.
Thanks again everyone for your help.
David
Good for you :)
I am a bit surprised but your testing does seem to demonstrate the limitation.
See you in March.
Rick
Rick
