Faulty C6880-X-LE supervisor
grneuendorf
Was hoping someone would be able to provide me with a spare part number or product ID that i could use to order a replacement supervisor for a C6880-X-LE switch?
This unit is not under warranty and is part of a Govt dept, so is not able to be returned for replacement. I need to know what I can order to fix this supervisor. The Datasheet say it uses a SUP2T - This platform also runs on the same architecture as the Cisco Catalyst 6500 Supervisor Engine 2T and therefore offers stability with a proven operating system software.
But there is line in the actual config to show any supervisor?
Reza Sharifi
The supervisor is part of the chassis.  There are 2 part numbers (see table-10 in this link).  The proper sup comes with a the chassis you order.  (X vs X-LE). I don't think you can just order the sup for this chassis.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6880-x-switch/data_sheet_c78-728228.html
