FEC teaming/channeling
sundara123
Community Member
I am very very new to Cisco IOS.So was this question.
1.How to set up 2950-24-SI swith for a teaming
I thought the following cong. works
Switch_A> enable
Switch_A#configure terminal
Switch_A#set port channel 0/0 -7 10 {desirable}
Switch_A#show port channel
Switch_A#show channel group 10
OR
Switch(config)#interface range fastethernet 0/0 -7
Switch(config-if)# channel-group 1 mode
desirable
Switch(config-if)#end
Is the above process is ok.
if not can any advise me How i can go further.
Thanks in Advance
sundara
alagrawa
Level 6
Level 6
Hi Sundara,
Thanks for writing in. Your second set of commands are mostly correct. The port would start from 0/1 instead of 0/0
Switch(config)# interface range fastethernet 0/1 - 8
Switch(config-if-range)# channel-group 1 mode desirable
Switch(config-if-range)#end
Switch#
The following link is a good link for configuring etherchannel.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea2/2950scg/swethchl.htm
Following link has some more examples for etherchannel. Some of the links have examples for 2950 also.
http://www.cisco.com/en/US/partner/tech/tk389/tk213/tech_configuration_examples_list.html
Hop this helps.
regards
-Alok
Thank you Alok san
(& also to other reader)
I am able to read the 2nd URL content only. bcos of my guest membership to the cisco.com.
As the Switch reached me on monday. i will test it before going line.
By the way this was my requirement
1.Fault tolerence implementation
2 ports will be used for one channel
one will be in the active and the other will be
in the dual mode
Thanks for your qucik reply
Sundara
-japan
If you remove the word "partner" from the 2nd URL Alok provided, you can get to the same content without having to log in to cisco.com. Try this one:
ETHERCHANNEL
Configuration Examples and TechNotes
http://www.cisco.com/en/US/tech/tk389/tk213/tech_configuration_examples_list.html
In general, when you see hyperlinks here in the NetPro forums that you want to read, but you don't have a "customer" or "partner" membership to cisco.com and the URL requires you to login, try removing the word "customer" or "partner" from the URL. Most of the time it will work.
