Category 6 cable pin-outs
CSCO10881970
I am used of using the Cat5 cabling on my working environment and now they want to move to using the Category 6 (1000Base-T) cable. Could someone show me on how could I do the CrossOver, Straight, RollOver cabling Pin-assingment on a Cat6 cable using the Cisco standard...
Thanks....
mhussein
Level 4
Level 4
The crossover pinout is the same for Cat 5, 5e and 6. For 1000base-T all 4 wire pairs are used, and Cat 6 is not really a requirment for gigabit; Cat 5e and most Cat 5 meet the specs.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/inst_aug/0bcabcon.htm#1003670
HTH,
Mustafa
Thanks, for the answer, I'l be trying it on my own.
A friend of mine keeps on insisting that Cat5 cable can't work using the Gigabit.
