FET work with B22 HP
Patrick McHenry
Level 4
Level 4
I want to connect a c7000, B22HP card to our 5548s. Can I use FET SFPs on the c7000 side and the 5548 side?
Thank you
I found this document a little unclear - this is what I referenced.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-b22-blade-fabric-extender/data_sheet_c78-685265.html
Pat,
It should not be an issue in using FET with the B22 series. Just make sure to use FET on both sides of the connection.
8 Replies 8
Reza Sharifi
Hi Pat,
FET only works between FEXs and the parent switches (7k, 6k, 5ks, etc..) and not between parent switches or parent switches to other vendors.
InayathUlla Sharieff
You can’t use FET’s for anything but connections to Cisco NX7K, NX5K, NX2K
  • Supported for fabric links only (Cisco Nexus 2000 Series to Cisco parent switch)
  • Cisco Fabric Extender Transceiver must be connected to another Cisco Fabric Extender Transceiver
  • Supported on Cisco Nexus 2200 platform uplinks
  • Supported on Cisco Nexus 5000 and Nexus 7000 Series Switch fabric link
So, I must use Standard 10GBASE-KR on the B22HP  side and FET-10G the 5548 side? Of must I use
The same on both? And if the same, what should I use on both sides? Not sure what the documentation is trying to tell us.
From what I understand the B22HP is supposed to look like a FEX from the 5548s side?
This is why I was thinking it might use a FET module.
Thank you.
Sorry for this but, I should clarify that the device is an N2K - B22HP - P V01
Thank you
Look at this sample from doc I attached
Source
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-b22-blade-fabric-extender/data_sheet_c78-685265.pdf
Here also - Thanks
Pat,
Thanks Reza
