few question on dhcp snooping,dynamic arp inspection.
sarahr202
Level 5
Level 5
Hi everybody.
I just want to verify  two things.
Dhcp snooping:
host1--------untrusted-f1/1--SW--f1/2--untrusted------Dhcp server.
When host 1  sends dhcp discover, sw1 will forward it out of f1/2 which is untrusted to dhcp server. However when dhcp server sends dhcp offer message sw1 will drop it because it is received on untrusted port.  This is my understanding  Is it correct?
Because I  was watching a you tube video on dhcp snooping in which the presenter claims sw1 will not forward the dhcp discover message out of f1/2 because it is untrusted.  Is it not true a switch configured with dhcp snooping monitors the incoming dhcp message on untrusted port ; sw does not monitor outgoing dhcp messages  on untrusted port?
Dynamic arp inspection:
h1------untrusted f1/1---sw---trusted----host2.
This is my understanding.
Sw will monitor all incoming arp request and response message on untrusted f1/1. . Sw  will not monitor the outgoing  arp response on f1/1 untrusted port. or will it?
thanks and have a great weekend.
2 Accepted Solutions
Jeff Van Houten
Level 5
Level 5
The answer to the first question is yes. Ports connected to the dhcp server should be marked trusted.
Peter Paluch
Hello Sarah,
No, this would not be a correct description. A client DHCP message (i.e. DISCOVER, REQUEST, INFORM, RELEASE, DECLINE) may never be forwarded out an untrusted port. It may be received on an untrusted port but it should never be forwarded out an untrusted port. This is to prevent other clients from eavesdropping on some other station's communication with DHCP server.
The presenter was correct.
This is true, however, we have to be more precise about the word "monitor". On an untrusted port, a DHCP Snooping-enabled switch automatically drops all server messages (OFFER, ACK, NAK). Client messages are permitted if they pass a certain set of checks. However, client messages can be forwarded out trusted ports only; server messages can be forwarded out only a port towards the client, and are never flooded, even if they are broadcasted by server.
Correct - DAI applies to incoming ARP messages, not to outgoing messages.
Best regards,
Peter
5 Replies 5
Jeff Van Houten
Level 5
Level 5
Hello sarah,
You are correct on both counts
Dhcp snooping -
An untrusted interface is an interface that is configured to receive messages from outside the network or firewall.
A
trusted interface is an interface that is configured to receive only messages from within the network.
Dai
Intercepts all ARP requests and responses on untrusted port
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Peter Paluch
Hello Sarah,
Best regards,
Peter
Thanks Peter.
Hi Peter
An extract from one of my books:
Dynamic ARP inspection is a security feature that validates ARP packets  in a network. Dynamic ARP inspection determines the validity of packets  by performing an IP-to-MAC address binding inspection stored in a  trusted database, (the DHCP snooping binding database) before forwarding  the packet to the appropriate destination. Dynamic ARP inspection will  drop all ARP packets with invalid IP-to-MAC address bindings that fail  the inspection. The DHCP snooping binding database is built when the  DHCP snooping feature is enabled on the VLANs and on the switch.
What does a switch configured with " DAI" check in a received arp message on   auntrusted port?
The extract from the book says mac-ip binding not a word about the port where such ip-mac is valid. For example if a switch has a dhcp binding as:
199.199.199.1    0000.000.0001      f0/1
A rogue computer connected to port f1/2 spoofs the ip address 199.199.199.1 and mac address 0000.0000.0001 will be successful in sending the arp message because as per book's extract, the mac-ip bindings matches.
I dont have the right equipment to test it out but my guess the switch should also check the port( i.e mac-ip binding and the port in my example it is f0/1) in dhcp binding not just mac-ip binding  to foil such attack.
what do you think?
Thanks.
