few questions about private vlan
sarahr202
Level 5
Level 5
Hi every body.
i have few questions about private vlan.
1) Can a private vlan have more than one promiscuous port?
2)   consider the following scenario:
sw1---trunk-----sw2-------trunk-----sw3----trunk------------router
sw1 has vlan 1
sw2 has vlan2
sw3 has vlan3
We want to implement private vlan feature on vlan1
We implement that feature as;
vlan1 primary
vlan 4 secondary
vlan 5 isolated.
We want  these vlans( vlan1,4,5)  to communicate with each other at layer 3.  But  sw1 does not have any port connected to router  , so we can not assign any port as promiscuous port.    How can we acheive  that goal i.e enabling communication at L3  among vlans 1,4, 5?   please note that   we want  limited communication among these   vlans 1,4,5   for that  we already  configured access lists on router.
3)  consider the following scenario:
sw1------trunk------------sw2----trunk  ----sw3--Dhcp server
Sw1 has vlan1
sw2 has vlan 2
sw3 has vlan 3
Dhcp server is in  vlan3
we want hosts in vlan 1   be assigned ip address from the pool    1.0.0.0/8
we want hosts in vlan 2  be assigned ip addresses from the pool   2.0.0.0/8
we face following challenges.
1)   dhcp server  being in vlan3  can not hear any dhcp requests from hosts in vlan 1 and hosts in vlan2.
How can we overcome this issue?
2)  Given that  we overcame the above issue,  we face yet another challenge  . In order  for dhcp server to assign  ip address from the pool 1.0.0.0/8
Dhcp must be able to   tell which dhcp  requests come from vlan 1 hosts and which dhcp requets come from vlan2 hosts.
How can we overcome this challenge?
Thanks a lot and have a nice weekend.
Ganesh Hariharan
Hi every body.
sw1 has vlan 1
sw2 has vlan2
sw3 has vlan3
vlan1 primary
vlan 4 secondary
vlan 5 isolated.
Sw1 has vlan1
sw2 has vlan 2
sw3 has vlan 3
Hi Sarah,
What is the switch series in which vlans are confgured and need to have private vlan configuration because following is the switch support feature for private vlan configuration, check out the below link for more information
http://www.ciscosystems.ch/en/US/products/hw/switches/ps708/products_tech_note09186a0080094830.shtml
and  A promiscuous port can communicate with all interfaces, including the isolated and community ports within a PVLAN.
Hope to Help !!
Ganesh.H
