02-07-2017 11:28 AM - edited 03-08-2019 09:13 AM
Hello Friends,
Is it possible to monitor via SNMP the status of a FEX 2K Connected to a 7K? We would like to monitor if it is online or offline and also the power supplies status.
02-07-2017 04:30 PM
I'm quite sure that you would monitor the module status on the 7K to determine if a FEX is online. The FEX itself has no management platform but is controlled fully by the 7K.
02-08-2017 12:47 AM
If your monitoring the 5k or 7k and logging that it will tell you when the 2k PS fails as its like a line card , It only happened me the other day , my monitoring systems picked up the alert and notified me , 1 more thing to do now :)
2017 Feb 4 12:09:08 xxxxxxxxx %SATCTRL-FEX108-2-SOHMS_DIAG_ERROR: FEX-108 System minor alarm on power supply 2: failed
2017 Feb 4 12:09:11 xxxxxxxx %SATCTRL-FEX108-2-SOHMS_DIAG_ERROR: FEX-108 Module 1: Runtime diag detected major event: Voltage failure on power supply: 2
