Inter Vlan Routing
faiziasif8
I am relatively new to the use of Packet tracer. I have been given a problem by my supervisor. Please refer to the picture attached.
I had made 3 vlans. Vlan 10 consists of PC 1 and 11. Vlan 20 consists of PC 2 and 22 and Vlan 30 consists of 3 and 33. I have to ping PCs pf VLan 20 and Vlan 30 without using a router or a multi layer switch. From what i understand to establish communication between Vlans we need a router pr a multi layer switch. Is there any solution to my problem?
I shall be very grateful for any help!!
Yes, you are right..You can use "Router on a stick configuration" or "L3 switch with IP Routing" enabled in order to solve this..Only with Layer 2, Inter-vlan routing is not possible..
Best Regards,
Rikshit
Best Regards,
Rikshit
Thank you!
I have another question. Is it possible to use static routing to solve the problem?
I guess, it will not work. Even if the traffic flows to the default gateway, how it will access the other Network.. It won't be possible..
