FEX 2K
Hoang Hung
Hi guy
we are configurating Fex feature switch Nexus 2k with nexus 7k . But I have a question.
If version Fex switch bigger core switch >>> What happen ?
Please help me
Thanks guy
9 Replies 9
Andrea Testino
Hoang,
Are you asking what happens if the FEX has an NX-OS image that is newer than the NX-OS image running on the parent switch?
- Andrea, CCIE #56739 R&S
Hi  @Andrea Testino
Yep. If  NX-OS image running on the parent switch newer FEX NX-OS, FEX OS will uprade OS from parent .
But If if the FEX has an NX-OS image that is newer than the NX-OS image running on the parent switch >> What happent ?
I know. If  NX-OS image running on the parent switch newer FEX NX-OS, FEX OS will uprade OS from parent .
The FEX image will be downgraded to match the parent switch.
Thanks @Reza Sharifi.
Are you sure ? Please sent to me document writen it. If you have.
Thanks you so much .!
Hi guy
FEX will auto downgraded or manual downgrade OS?
Think of a FEX being a blade in a chassis. The FEX is just a blade and gets the upgrade/downgrade from the parent switch.
Thanks you so much @Reza Sharifi
Reza Sharifi
Whatever version you load on to the 7k, it will get pushed to the FEX. So, FEX will have the same exact version as the parent switch.
