FEX cable limitations
ssieger
Level 3
Level 3
is there any restriction about the distance between a fex and its 5548UP parent switch? The N2K-C2248TP-E-1GE is able to support the following SFP's:
SFP-10G-SR
SFP-10G-LR
FET-10G2
SFP-10G-ER
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
So if i use a LR SFP is it possible to put my fex 10km away from its parent switch ?
Greetings,
Stephan
acampbell
Stephan,
The spec for these 2 says 10 or 40 KM
Cisco SFP-10G-LR
Cisco SFP-10G-LR-X
1310
SMF
G.652
10km
Cisco SFP-10G-ER****
1550
SMF
G.652
40km**
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
