FHRP Gateway Optimization in an OTV Network across DC's
Bilal Nawaz
The ways that I've been told about how to stop FHRP protocols from talking over an overlay has been to use a combination of VACLs and MAC filters. There is a cisco doc that also shows how to do this. On some newer versions of IOS ive seen the option to block any FHRP over the overlay. I haven't seen much on the web for this command...
<http://www.cisco.com/en/US/docs/ios-xml/ios/wan/command/wan-m1.html#GUID-3E20C339-68D0-4471-8D05-B9E3C9BB61EA>
OTV_DC1_ASR1#conf t
OTV_DC1_ASR1(config)# interface overlay 1
OTV_DC1_ASR1(config-if)# otv ?
  control-group         OTV VPN control multicast group
  data-group            Multicast group range for data
  encapsulation-format  Encapsulation format
  filter-fhrp           Configure to not forward HSRP, GLBP, and VRRP packets on overlay
  isis                  ISIS interface subcommands
  join-interface        OTV VPN join-interface
  suppress              Enable overlay packet suppression
  vpn-name              OTV VPN name
OTV_DC1_ASR1(config-if)#otv filter-fhrp
Has anyone tried this with a L2 ACL?
Kind Regards,
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
sdavids5670
Level 2
Level 2
Here's what we have in our 7K configuration:
In global config:
ip access-list otv-hsrp-filter
  10 deny udp any 224.0.0.2/32 eq 1985
  20 permit ip any any
mac-list hsrp-vmac seq 10 deny 0000.0c07.ac00 ffff.ffff.ff00
mac-list hsrp-vmac seq 20 permit 0000.0000.0000 0000.0000.0000
route-map hsrp-filter permit 10
  match mac-list hsrp-vmac
On the L2 interface between the OTV VDC and the distribution VDC:
interface port-channel41
  ip port access-group otv-hsrp-filter in
Then:
otv-isis default
  vpn Overlay1
    redistribute filter route-map hsrp-filter
