%FIB-3-NOMEM - IOS bug or ARP cache problem
johnlloyd_13
Level 9
Level 9
hi all,
today, one of our 1841 had a slow connectivity and packet drop issue. my telnet session was very slow and found syslogs below.
there was no high CPU but i've observed a high memory usage. i've also observed ARP table output was very long (from 1.0.0.0/24 up to i don't know what).
i've found a similar issue found on link below but i'm not sure whether it's related and can also affect an 1841 router. please advise if my IOS hit a bug or was it just an ARP cache/memory or CEF/FIB problem? thanks in advance!
https://supportforums.cisco.com/thread/204558
#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 12:41 by prod_rel_team
*Nov 11 20:56:39.758 SGT: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes
failed from 0x6028FAE0, alignment 16
*Nov 11 20:56:39.762 SGT: %FIB-3-NOMEM: Malloc Failure, disabling CEF,
-Traceback= 0x60AF1A14 0x60CAA824 0x60CAFC78 0x60CB6414 0x6088E43C 0x60CDFED0
0x60E96140 0x616BBBC8 0x616BBBAC
#sh proc cpu sort
CPU utilization for five seconds: 1%/0%; one minute: 2%; five minutes: 1%
#sh mem stat his
------------------ History of Processor Mempool ------------------
<SNIP>  10:46:14 AM Monday Nov 12 2012 SGT
    999999999999999999999999999999999999999999999999999999999999
    333333333333333333333333333333333333333333333333333333333333
100
90 ************************************************************
80 ************************************************************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6
             0    5    0    5    0    5    0    5    0    5    0
               Free memory per second (last 60 seconds)
Yes, It should be due to the static route. Just check the output of 'show memory stat' once in 3 days and see if the memory usage is stable.
If nothing seems alarming after a week or so, your issue is resolved.
Karthic
5 Replies 5
skarthic
Hi John,
Your FIB-NO-MEM message is due to the low memory condition. We will have to concentrate on why the router is is having low memory.
Please collect the following outputs ASAP
show process memory sorted
show memory alloc totals
Karthic
If you have a huge ARP cache, it might have to do with static routes pointing out of the interface rather than using the next hop ip.
Can you also post
show run | in ip route
Karthic
hi karthic,
i will post the show command output if the issue happens again. i've observed the connection has been stable (telnet also became faster) after our client reluctantly rebooted the router, although the ARP table is growing bigger again.
yes, you're right on the static route issue as well. the network engineer who setup the router used an FE port as exit interface instead of the ISP's next hop IP. this one has been resolved earlier.
so this ain't due to an IOS bug (i hope not)?
Karthic
Raju Sekharan
Please paste the following output
Show proc mem sort
Do you have any static default route pointing to any broadcast interfface?
attach your configs too
Thank you
Raju
