fiber duplex
carl_townshend
Hi all, is it possible to run half duplex over fiber, or can you only run full duplex ?
5 Replies 5
s.marino
Level 2
Level 2
Fiber connectivity is at Full Duplex only.
Hope this answered your question.
Sal
why can it only run at half duplex ?
sdrossen2
Level 3
Level 3
What are you wanting to accomplish with running fiber at half duplex? The answer as Sal said is no but there has to be a reason why you want to do this.
Hi there, it is more of a technical question of why we cant do it ?
If you're asking 'can you run fiber using only one strand instead of two' then the answer is yes - with BX SFPs you can use only a single strand, at two different wavelengths.
With fiber, you have either 2 distinct fibers (normal runs) or 1 fiber at 2 wavelengths (BX interfaces), so there's always a dedicated send and receive line - there's no need for half-duplex.
