Fiber port of switch does NOT working
eeebbunee
Recently some of switches I have has been shown faulty issue on Fiber port.
I have seen this kind of issue on both '3750X series and 2960X series', and issue is following:
   - Swithes are 48- Ethernet ports PoE + 4 Fiber ports
   - 3750X switch = 3/4 ports are currently plugged with Cisco GBIC module.
      2960X switch = 1/4 port is currently plugged with Cisco GBIC module.
   - I plugged new Fiber cable with new GBIC module, but switch port is NOT working (no blinking).
   - Show int status result:
   - I tried Port shutdown and no shutdown, but no different.
   - Try another GBIC module, still not working.
Do you think my fiber port has faulty? Is there any command line that I can check the port status?
Thank you very much.
11 Replies 11
ammahend
make sure you are maping Tx to RX and vise versa, if its multimode, you can check the light,  if its single mode, just try reversing the fiber cable and see if it works.
-hope this helps-
Reza Sharifi
There is no command to test the fiber port. Can you try a different fiber patch cord?
Also, are you using the correct fiber patch with the correct SFP?
If the fiber is single-mode, you need single-mode SFPs.
If the fiber is multimode, you need multimode SFPs.
Hello, Thank you for your response.
Fiber cable is multi mode, LC-LC type(OM4 Duplex multimode, aqua color) and module is also multimode (Cisco GLC-SX-MMD).
I also tried fiber patch cord (1,2 - 2,1 or 1,2 - 1,2), but still does't work.
When I plug device (firewall), firewall port is blinking (uplink is fine).
However, only switch port gives me 'notconnect' interface status..
I am facing same problem.
Did you get any solution.
Please share with me.
Thanks.
the same problem meaning on the same device (3750X/2960X) switches ?
I have Cisco C9300X-12Y switch (SW Version : 17.09.03),
and Sonicwall NSA5600
Firewall and switch are connected by fiber optic cable
multimode fiber
SFP "GLC-SX-MMD" on both side.
Sonicwall port comming up but cisco switch port show down.
I gave the command "speed nonegotiation" , but still does't work.
Thanks.
understood. Can you post the output of 'sh int' of the interface on the 9300 that is connected to the SonicWall ?
Please find below
Switch#sh int TwentyFiveGigE1/0/12
TwentyFiveGigE1/0/12 is down, line protocol is down (notconnect)
Hardware is Twenty Five Gigabit Ethernet, address is 9088.5553.2d8c (bia 9088.5553.2d8c)
MTU 1500 bytes, BW 25000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseSX SFP
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 9 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch#
Switch#
Switch#sh run int TwentyFiveGigE1/0/12
Building configuration...
Current configuration : 80 bytes
interface TwentyFiveGigE1/0/12
switchport mode trunk
speed nonegotiate
end
Switch#
Switch#
Switch#sh int TwentyFiveGigE1/0/12 statu
Switch#sh int TwentyFiveGigE1/0/12 status
Port Name Status Vlan Duplex Speed Type
Twe1/0/12 notconnect 1 full 1000 1000BaseSX SFP
Switch#
Switch#
Switch#
Thanks.
as far as I recall, the SonicWall lets you set either AutoNeg or 1G. On the Cisco, I think you cannot set the speed, so make sure that both sides are set for Autoneg.
https://www.youtube.com/watch?v=gORYoiCp-Sg
this video help you,
check command use to check the Fiber health
Leo Laohoo
Loop the fibre and see if the LED goes green/amber or not.
