Find out Bandwidth used on interface
Justin Westover
Is there a way I can find out the amount of bandwidth i'm using on a particular interface on a 4507 cisco multi-layer switch? It is a gig port and I have it setup for monitoring (spanning) and I see packets being dropped in the "Total Output Drops" area. To me it looks like it must be exceeding the 1gig limit but I don't know a way to check to make sure. I also have the queueing strategy set to FIFO.
5 Replies 5
glen.grant
  For a snapshot  you can use show int summ  and that will give you bps , packets etc...
Kimberly Adams
Level 3
Level 3
Justin,
If you know the specific port that you want to check, then you can run the command that Glen suggested or show int [fastethernet or gigabitX/X].
Here is an example from a different kind of switch.
sh int fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is b8be.bfc4.ff81 (bia b8be.bfc4.ff81)
  Description: TRUNK TO AT&T ROUTER FA0/0
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 4/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 131000 bits/sec, 124 packets/sec
  5 minute output rate 1602000 bits/sec, 213 packets/sec
     1061017156 packets input, 135745243577 bytes, 0 no buffer
     Received 19694 broadcasts (17437 multicasts)
     0 watchdog, 17437 multicast, 0 pause input
     1835909260 packets output, 1670293894611 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
I do hope this helps.
Cheers,
Kimberly
Thanks and Cheers! Kimberly Please remember to rate helpful posts.
singhaam007
Level 3
Level 3
hello justin,
first of all change the input rate to 30 seconds.
config t
load-interval 30
exit
then use
sh int f0/1 | inc drops|bits
it will show you how much trafic going through or any packet drops as well.
keep repeating it again and again and you will get some good information.
please rate if its helpful
thanks
the command ( load-interval 30 ) does`t works in cisco 3900 router
I need some help
