Find Switch and Port using Macaddress on Port-Channel
ralpho1
Hello togehter,
I need to know which Device is connected to a switch port. My starting Point is on Coreswitch where I enter:
show mac address-table | inc abcd
Output is:
show mac address-table | inc abdc
   4    aaa.bbb.abcd    DYNAMIC     Po1
Now I stuck because I can´t get more Information about which Switch it is because
"show cdp neighbors port-channel xy details" won´t work. Does this support not any Switches or I ´am completely wrong?
or is there an other way?
Many Thanks and Regards
Ralph
SW1-SW2-----
in SW1 you see
   4    aaa.bbb.abcd    DYNAMIC     Po1 <<- this is MAC learn in VLAN 4 via PO1
NOW in SW1 if PO1 is trunk
then do
show cdp <<- check see which SW neighbor show connect via PO1
then go to that SW do
see the MAC must appear connect to VLAN 4 and it can learn via access or trunk
MHM
acampbell
In the 1st place try sh int port-channel 1  about 10 line down it should say what interfaces are making up the port channel, then hopefully you can use sh cdp nei for that interface , or may by sh udld x/y/z to get the name of the next switch where the mac is coming  from.
Regards, Alex. Please rate useful posts.
SW1-SW2-----
in SW1 you see
then do
MHM
Many Thanks to all, this works.
Ralph
