Finding a Subnet Mask
Cisco-Spider
Community Member
Any one have an idea that how can we find a subnet mask from an IP range ?
Example:
If we have a range of IP addresses Like
1.1.0.1 --> 1.1.5.254
Please help
andrew.prince
Level 11
Level 11
See http://www.vlsm-calc.net/
Oleksandr Nesterov
1.1.0.1 -> 1.1.5.254
Let's translate both addresses into binary form:
00000001.00000001.00000000.00000001 -> 00000001.00000001.00000101.11111110
Let's see which bit's have changed from the lowest to the highest address:
00000001.00000001.00000[000.00000001 -> 101.11111110]
So we can see that  21 bit left the same, and 11 bits changed:
If we really picked up the first and the last addresses we can assume that  network portion (or network mask) is 21 bits, and host portion is 11 bits.
So your network address is 1.1.0.0 (because network address is where all host bits are set to 0 )
And your broadcast address is 1.1.5.255 (all bits set to 1)
Network can be written ad 1.1.0.0/21 or 1.1.0.0 255.255.248.0
HTH,
Alex
Also you can become expert in subnetting by playing the 'subnet game' . Just visit the link below-
https://learningnetwork.cisco.com/docs/DOC-1802
