Finding an issue inside the same vlan
girchand
Community Member
Hello Folks,
I faced recently an issue where there is a vlan 40 with ip address 172.16.0.0/23 and int vlan 40 is 172.16.1.1/23.There is also a firewall with ip 172.16.1.2/"24" int the same vlan.
There are users and some test servers also in the same vlan.
Issue:- Users in 172.16.0.3-171.16.0.254 is able to ping servers in 172.16.1.0-172.16.1.254.But users in 172.16.1.0-254 is not able to ping servers in 172.16.1.0-254.
eg:172.16.0.100 is able to ping server 172.16.1.150 but 172.16.1.100 is not able to ping server 172.16.1.150.
Customer told -after removing a newly created ip sec tunnel in firewall issue got resolved.
I am trying to find out why the packet went to firewall for the above traffic flow.
Gireesh
6 Replies 6
Martin Carr
Level 8
Level 8
Because the networks overlap!
Martin
Hello Martin,
Subnet is 172.16.0.0/23 and the subjected users and server is in same subnet even if 172.16.1.X or 172.16.0.x
Gireesh
The Firewall is on a different network, which overlaps with the other.
Is it a PVLAN?
Martin
no pvlan.Firewall is in same vlan
glen.grant
  Network connectivity is always going to be strange when you have devices within the same address range but they are using different subnet masks .  This is a no no and will lead to unpredictable results .
yeah,but customer is having this config from years and its under revamp
