Firepower Sub-Interfaces not receiving traffic
alex-j-seal
Hi All,
Any help I can gather here would be appreciated.
We are currently migrating from ASAs to 2 FPR1140s in HA pair. We have the outsides configured and we have a few interfaces populated.
Currently we have an ASA HA pair that has 2 sub interfaces on its inside connection. One for Wireless and one for Ethernet connections.
This sub int is 10.10.1.x/24 and all of our VLANs route traffic to it via the Catalyst switches using defined routes on the switches.
When recreating this set up on the FTDs we are not hitting the FTD when trying to change the routes defined on the switch.
The route on the switch is:
Ip route 0.0.0.0 0.0.0.0 10.10.1.x (the sub interface ip)
But our L3 VLANs are not hitting this address to get out to the Internet.
Each VLAN has its respective address filled out as the .1 of that range and they are all /24.
Is there a fundamental difference that I am missing between ASAs and FTDs and how they handle traffic in the scenario we have?
The reason we route the traffic on the switch is that we have a fail over line that goes through to a DC we have.
Please any guidance would be helpful.
A
If ypu have subinterface for all vlan in ftd and this subinterface IP is GW IP for hosts then staitc route not work
You need
Vlan SVI in SW be GW IP
transit vlan OR router port between SW and ftd and use this vlan to forward traffic to ANY (defualt route)
MHM
10 Replies 10
What vlan you use to connect SW to FTD ?
Are you sure interface is UP and enable?
MHM
Hi thanks for the response,
The VLAN is our VLAN11 on the switch, it has a corresponding sub interface mapped to VLAN11 as well. The IP used for this address on the sub int is .253 and .254 for the standby.
The switch has an IP configured for this VLAN of .1.
It is up and enabled, the connection from the switch to the FPR is a dot1q trunk allowing all VLANs.
We can ping .253 and .254 from the switch, and on the firewall we can ping the .1 address. The problem comes when we try to push the routes on the switch to this .253 address, nothing can see it.
Try to ping it from any other VLAN and it dies, ping from the VLAN11 and it can see .253
A
Static route need to be toward active FW
Also can I see topolgy thanks
MHM
alex-j-seal
Static route needs to be towards the Firewalls active IP? Being the management IP rather than the sub interface IP?
I can get topology next week, I am no longer on premises.
A
Subinterface IP of active unit
Otherwise the traffic will drop
MHM
OK yeah, that's how we have it. It's going to the sub interface IP of the chosen VLAN. Which is the .253.
We were attempting to route all traffic through one VLAN rather than have a sub interface for every single VLAN we have.
Every VLAN on the switch is being routed on the switch and so we thought there may be L3 conflicts between the FTD and the Catalysts.
A
You need
MHM
Thank you for this, so doing some further reading I want an Access port not a Trunk from the switch to the firewall.
And then use the VLAN assigned to just transit traffic.
Point our static routes to the interface IP and then we should see traffic flow.
Please tell me if we have this wrong.
Many thanks
A
Just to clarify
Solution
Sw(vlan xx)-access port-l3 port in FTD
L3 port in ftd have IP in same subnet of vlan xx
The SW have VLAN SVI for vlan xx
The SW use defualt route toward active unit L3 port ftd
MHM
Got it!
Thank you, I will put it into effect next week and feedback.
A
