Firmware upgrade on WS-C3850-48T
I am planning to upgrade Cisco 3850 stack switch and turning my head at the experts here for inputs/help.
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.04SE RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 29-Aug-14 22:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
C3850-48T uptime is 3 years, 21 weeks, 2 days, 6 hours, 56 minutes
Uptime for this control processor is 3 years, 21 weeks, 2 days, 7 hours, 3 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
C3850-48T#sh mod
Switch Ports Model Serial No. MAC address Hw Ver. Sw Ver.
1 56 WS-C3850-48T FOC1814X0KR 544a.0041.d600 V03 03.03.04SE
2 56 WS-C3850-48T FOC1814X0KD 544a.0081.dd80 V03 03.03.04SE
C3850-48T#dir
Directory of flash:/
69707 -rw- 2097152 Feb 13 2018 07:41:03 +00:00 nvram_config
69709 -rw- 1248 Oct 2 2014 01:24:54 +00:00 packages.conf
69706 -rw- 976 Jun 4 2014 09:33:51 +00:00 vlan.dat
13 -rw- 79110340 Oct 2 2014 01:24:50 +00:00 cat3k_caa-base.SPA.03.03.04SE.pkg
14 -rw- 6521532 Oct 2 2014 01:24:50 +00:00 cat3k_caa-drivers.SPA.03.03.04SE.pkg
15 -rw- 34530288 Oct 2 2014 01:24:50 +00:00 cat3k_caa-infra.SPA.03.03.04SE.pkg
16 -rw- 34856268 Oct 2 2014 01:24:50 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EZ4.pkg
17 -rw- 25172880 Oct 2 2014 01:24:50 +00:00 cat3k_caa-platform.SPA.03.03.04SE.pkg
18 -rw- 77445952 Oct 2 2014 01:24:50 +00:00 cat3k_caa-wcm.SPA.10.1.140.0.pkg
On Cisco website I only see bin file "cat3k_caa-universalk9ldpe.SPA.03.06.06.E.152-2.E6.bin" to download not packages file. I followed below Path and Chose Catalyst 3850-48T-E
Downloads Home> Products> Switches> Campus LAN Switches - Access> Catalyst 3850 Series Switches> Catalyst 3850-48T-E> Switch IOS XE Software-3.6.6E(MD)
I am looking for answers on three questions.
1. cat3k_caa-iosd-universalk9.SPA.150-1.EZ4.pkg is my current firmware?
2. Am I looking at right IOS file to download?
3. Can I upgrade directly from 03.03.04SE  to cat3k_caa-universalk9ldpe.SPA.03.06.06.E.152-2.E6.bin
Raghav.
Mark Malone
03.03.04SE is current looking at your output
you can direct upgrade from 3.3.4 to 3.6.6 it may take a bit longer as the microcode needs to be upgraded but there is no interim image required
you can but your changing from bundle mode to install mode , i use bundle mode .bin some use pkg as it uses less memory on install , you can use either choice is yours but there installed a differently way so read the doc below
Good doc explaining both simply
https://supportforums.cisco.com/t5/network-infrastructure-documents/3850-switch-ios-xe-upgrade-detailed-standalone/ta-p/3138609
Mark Malone
Seb Rupik
Hi there,
Your current firmware version is 3.3.4SE
Yes, 3.6.6E is the current recommended version of firmware.
Yes, copy the file to flash and issue the following command:
request platform software package install switch all file flash:/cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin auto-copy
cheers,
Seb.
