ā09-20-2011 10:41 AM - edited ā03-07-2019 02:19 AM
I have a 2960G and I use the Express Setup mode to connect for the first time on the switch with Internet Explorer.
All goes well, I can connect my laptop to the switch with 10.0.0.1 IP address (using Interner Explorer), but a windows asks me a "user name and password" for level 15 access, when normally there is no password or username.
Thank you for your help
Solved! Go to Solution.
ā09-20-2011 04:12 PM
Try "cisco" and "cisco" (no quote marks) for username and password. Actually, you can probably get away with not putting in a username - I think the switch will ignore tha username anyway, and just look for the password "cisco" (minus the quote marks).
Cheers.
Cheers.
