First Hop Redundancy Protocol
shaharshad
I have config like
SwA & SwB (VSS1)---Connected to ---> SwC & D (VSS2)
Now to make are server accessible primarily on VSS1 & secondly on VSS2. Should I run HSRP? Any other thoughts
ahmedshoaib
Level 4
Level 4
Hi;
It's depend on your network requirement. You can also run HSRP b/w VSS1 & VSS2 and you can also enable L3 routing between VSS1 & VSS2.
Note: As you opened case with reference to FHRP, FHRP is required when you are running OTV b/w 2 sites running on Nexus.
Thanks & Best regards;
